05-23-2019 | #1 |
Pulley Failure
So a couple of years ago my tensioner went bad and I rebuilt it using a combination of stuff including some L98 parts and this aluminum pulley from UPR products (the pulley specs as a 85-93 Mustang ultra light tension/idler pulley). I remember I followed the tensioner rebuild project of someone on here, so if you have this pulley I suggest you check it. I can't think of any reason other than poor build quality as the cause, there are actually several holes although you can only see the one in the pic. The belt shows some damage too, I was noticing some odd coolant temp and voltage fluctuations which is why I started poking around. Guess I'll go back to the factory pulley.
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
05-23-2019 | #2 |
Re: Pulley Failure
Bearing failure?
H
05-23-2019 | #3 |
Re: Pulley Failure
Possibly... I have been noticing a silvery oily residue under the air horn and around the general vicinity of the belt. Although I think that is from a leak in the A/C system which is another area I need to address and that could also account for belt slippage.
05-23-2019 | #4 |
Re: Pulley Failure
LB,
Looks like it wasn’t worth the extra hp.
05-23-2019 | #5 |
Re: Pulley Failure
Judging from the hole in the pulley (which is aluminum) looks like it froze and the belt wore a hole in it, might be the source of your silvery residue?
H
05-23-2019 | #6 | |
Re: Pulley Failure
Hmmm, that's a good possibility
05-23-2019 | #7 | |
Re: Pulley Failure
Bob: I replaced mine with a GM pulley for a C4 LT1. Works no for over 10 years! Also, Jerry's Gaskets has ZR-1 pulleys, IIRC.
05-23-2019 | #8 |
Re: Pulley Failure
After looking closely at the photo appears it could have started as fatigue crack.
Is the center section of the pulley solid or spoked? Sent from my iPhone using ZR-1 Net Registry
05-23-2019 | #9 |
Re: Pulley Failure
Pretty sure Jim Voter had that exact same pulley fail on the way home from BG
05-23-2019 | #10 |
Pulley Failure
It’s hard to imagine that billet aluminum is weaker than plastic (stock) and I agree it has to be bearing failure with a seize that heated and burned by the belt friction. It would seem that would be noticeable though. I’m tempted to go back to stock myself. I guess another reminder to make America great again and we need better quality parts overall and stop outsourcing if this is from China.
I can’t remember the Dynomite post. Was it bigger and needed and larger belt too? If same sized belt used it could cause more tension on the pulley than it should have? Thanks for sharing since some of us did this mod. Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 Last edited by HAWAIIZR-1; 05-24-2019 at 06:11 PM. |
