05-03-2019 | #1 |
Next question.......ABS light.....how to disable?
Hello all,
My car had its ABS disabled years ago when the front brakes were installed. Any way to get rid of the unsightly service ABS light in the info center? As always, thanks in advance! Tony Sent from my iPhone using ZR-1 Net Registry |
05-04-2019 | #2 |
Re: Next question.......ABS light.....how to disable?
Pull the light bulb
05-04-2019 | #3 |
Reconnect the ABS ... on my 91 there is a power connector in the cubby behind the driver's seat. There is no good reason to disable the ABS unless the system is defective and no parts are available.
05-05-2019 | #4 |
Thanks guys, I don’t see a way to connect it back up since the original front brakes are long gone.
05-05-2019 | #5 |
has the ABS controller been removed too?
05-05-2019 | #6 |
Um, ABS sensor is in the bearing assembly, my front OEM brakes are long gone too, my ABS are fully functional still. Get yourself a Factory Service Manual. It will prove useful
05-05-2019 | #7 | |
H
05-05-2019 | #8 |
Thanks guys I am still new to this car. I do see where the wires mount to the hub. I saw a loose connector and I assumed it was for the ABS.
That being said, if the ABS is behind the passenger seat in the compartment the whole unit has been removed. Sent from my iPhone using ZR-1 Net Registry |
05-05-2019 | #9 | |
ABS is behind the Driver Seat, not the passenger seat
05-05-2019 | #10 |
Under the tray and possibly some insulation.
H
