![]() Join Date: Feb 2017
I need to replace my Battery. I am looking for a picture of what the original battery looks like. I have the 1993 Service manual but the drawing lacks detail of what the real decals on the Delco Remy Battery stickers looked like. If you know of a source for Stickers or a new battery with correct stickers I am interested.
Thanks, Dave Noble dnobull #180 |
![]() Join Date: Oct 2004
I've seen these a few times and believe they'd be correct label for a '93. This is a very old post I've seen here and on the CF many times.
http://zr1.net/forum/showpost.php?p=54383&postcount=6 I use a browser add-on that displays previously locked PB snapshots. I don't know that these are PB snapshots or not. I don't know that battery specifics and catalog # for various years is included in Registry Member access or not. If not it would be an interesting 'add' I'd think. ***If you have the 'build sheet' for your car the battery is ID'd on that sheet. Not sure the 'block #' for a '93 but '95 is likely block 47. Then a GOOGLE search should get you appropriate information. Last edited by WVZR-1; 11-19-2018 at 10:03 AM. |
Thank you,
Since I posted this I found an excellent graphic which I believe I can use to print my own decal. I have puchased decal printing material from a company in Texas. I will get a battery from a GM dealer and pull the original decal off to apply mine. Happy Thanksgiving, Dave |
#4 | |
![]() Join Date: Sep 2008
Will certainly cover your costs and whatever for your time. Thanks, Marty |
#5 | |
This AM the images of the battery worked well with my browser. The battery image and part # was correct? |
![]() Join Date: Jan 2018
What is the correct replacement Battery??. NCRS book shows Model 75-695 and CCA rating of 695 amps which I can not locate in a Delco Freedom battery.
Any help would be appreciated. Thank you |
I went to a Chevy Dealer and bought the closest thing but asked for the top to be Flat. That way I could put a copy of the old Delco Remy Battery sticker with a copy of the Green site glass on the top of the battery. I had to peal off the original stickers and put them on the side of the battery so that I could claim warranty if needed.
Send me an email to dnobull@gmail.com and I will send a copy of the sticker that you can print on glossy paper and use double sided scotch tape to adhere it to your battery |
Tags |
1993 delco remy battery, battery, delco |
