Old 10-31-2018   #1
zr1assassin
zr1assassin's Avatar
Default Valeo stock pressure plate with new clutch/flywheel?
I ordered an aluminum flywheel and a centerforce clutch, question is just use the stock pressure plate? is it a valeo?
zr1assassin is offline   Reply With Quote
Old 10-31-2018   #2
Ccmano
Ccmano's Avatar
Default Re: Valeo stock pressure plate with new clutch/flywheel?
Yes, Valeo....
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 10-31-2018   #3
zr1assassin
Thanks 😉👊
Old 10-31-2018   #4
Ccmano
Ccmano's Avatar
A couple of considerations. ZR-1 PP’s are discounted. Although Jerry appears to have new old stock (I think) and I have a used one (pictured). PP’s sold today are the LT1 Version that is identical other than mounting flange thickness which is thinner. The difference is minimal and they work fine. There’s a thread here where Jerry outlines the details and the bolt issues. Worth reading the whole thread.
http://www.zr1.net/forum/showthread....late+thickness
Longer bolts are currently unavailable specifically for this application unless you want to try and spec them yourself. The Fidanza will have to be drilled and tapped for the longer bolts if you go that route. As I understand it Haibeck uses the stock bolts with the ZR-1 PP on a Fidanza FW.
Just some food for thought.
H
Old 10-31-2018   #5
zr1assassin
I'm going to reuse my pp if possible, it has 20k miles on it
Old 10-31-2018   #6
Ccmano
Ccmano's Avatar
Should be fine, that’s what I did.
H
Old 10-31-2018   #7
zr1assassin
Awesome thanks
Old 10-31-2018   #8
rush91
Off topic, but your new wheels look amazing!!!
rush91 is offline   Reply With Quote
Old 10-31-2018   #9
zr1assassin
Thanks man! Just finishing up the build. Did coilovers/ calipers/wheels. It sets the z juuuust right 😉
Old 11-01-2018   #10
Flyman 27
Flyman 27's Avatar
I recently had my clutch/flywheel asm replaced by Mark. He highly recommended that I not use the lighter weight PP (I supplied one). He said that they were not rated to the higher RPMs that a ZR-1 requires. I can't remember what else he said about them. I got lucky, my take off PP was in great condition, so I got to reuse it.
I was replacing my aluminum Fidanza flywheel with an OEM Dual Mass flywheel for driveability reasons. I love the DM flywheel/clutch asm, all of my noise & vibration issues went away.
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
