Old 09-28-2018   #1
Jagdpanzer
Jagdpanzer's Avatar
Default Door Window Removal Advice
Have to do some work on diver side window regulator. Anyone have some pointers on how to best remove the widow?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-28-2018   #2
conesare2seconds
Default Re: Door Window Removal Advice
Following with interest. I need to repair or replace my DS regulator.
Old 10-11-2018   #3
ZWILD1
ZWILD1's Avatar
Either use the GM shop manual or you can buy a CD. Take some pics to help you remember how things are. Another suggestion is you probably can find a video on youtube of someone working on the C4 window regulator. While I have not had to do any repairs to my current car, I did remove both regulators from my sons 98 Trans Am to replace the electric window motors.
I made myself two window props out of some wood scraps with a U-shaped notch for the bottom of the glass and put rubber anti slip pads on the part that rest against the bottom of door. I did this to give myself some room inside of the door and so I didn't need to remove the window. If you have to mess with the bolts that hold the front and rear window tracks its best to mark their positions with a scribe or pencil.
91 Turquoise Metallic Haibeck 525 #0134
ZWILD1 is offline   Reply With Quote
