Old 09-27-2018   #1
Norwegianmopar
Norwegianmopar's Avatar
Default B&B fusion cat back exhaust
Anyone have experience with the fusion system? Is there a big difference between the two settings?
https://www.bbexhaust.com/shop/chevy...ust-fcor-0006/
Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin
1994 ZR-1 #112 Admiral Blue/Black
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
1991 ZR-1 #400 White/Red (SOLD)
Dana 4:10
Powder coated engine
Haibeck performance chip
Borla exhaust
Norwegianmopar is offline   Reply With Quote
Old 09-27-2018   #2
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Default Re: B&B fusion cat back exhaust
Yes!
One of the Best systems out there!!!
No F1 sound
More Muscle Car sound!
High quality!
VERY NICE!
( do you think I like it )
Marty
Old 09-27-2018   #3
What about Drone?
Old 09-27-2018   #4
Although my system is not B+B, it is a 3" ID using an Xpipe, NO resonator, DynoMax Ultraflow muffs utilizing C6Z06 NPP valves in tips. So basically, the B+B system for less $. I have a manual switch to open or close the valve on the inner tip. Flipping the switch, the aural difference between open and closed operation is quite noticeable, both outside and inside the car. I'd say 40% would not be overstating it. Its a very good sounding exhaust that is pretty quiet in a steady cruise mode even w both tips open. There are some areas in the rpm range where u get some vibration in the rear hatch area, and is subjective in terms of how much it bothers you. But at 70-80mph cruise, its a pretty nice setup. It also has a nice rumble at idle.
Old 09-27-2018   #5
Mystic ZR-1
Mystic ZR-1's Avatar
Originally Posted by DRM500RUBYZR-1 View Post
Yes!
No F1 sound
High quality!
VERY NICE!
Marty
Marty
What does Flo and the Gecko think?
Old 09-28-2018   #6
Top Toy
Top Toy's Avatar
Love the sound of the latest generation Fusions. And no drone, valves open or closed. Open sound is so good, I just ordered a set for my car without valves.
Sent from my HTC U11 using ZR-1 Net Registry mobile app
'95 ZR-1, aqua/gray, #167
368 LPE/Haibeck, Web cams, Stainless Works headers, B&B Fusion exhaust, 18" Fikse wheels, Alcon brakes, lowered. 491 SAE RWHP.
Top Toy is offline   Reply With Quote
Old 09-28-2018   #7
emmvette
emmvette's Avatar
I installed the B&B a few months back. Very little to no drone. My car is now drivable at highway speeds without giving me a headache!!
The directions suck but the system is great. I don’t notice as much difference on my car, I’d say about 30% in sound level. I have no CATS (substrate removed).
emmvette is offline   Reply With Quote
Old 09-28-2018   #8
Dennis,
Didn’t u just take a Fusion system off the car?
Old 09-28-2018   #9
rush91
Did you guys go with the full Fusion system or just the mufflers? If the full system, did you get the X-pipe or full resonator?
rush91 is offline   Reply With Quote
Old 09-28-2018   #10
The use of NPP valves eliminates the need for a resonator.
