Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Northeast Region
Old 09-13-2018   #1
stuntmanmike
Default Machine shop recommendation?
Hey, I would like to get my stock dual mass flywheel resurfaced. Can anyone recommend a machine shop in the NYC metro or Hudson Valley area? I keep the Z in New Paltz, NY.
Thanks in advance.
stuntmanmike is offline   Reply With Quote
Old 09-13-2018   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Machine shop recommendation?
A competent motor machine shop capable of surface grinding flywheels should be able to take care of it. Key step is to firmly block the secondary flywheel side to primary side so the clutch disk contact face is parallel to the crankshaft flange face side.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-14-2018   #3
efnfast
I've got a local parts supplier that does that. Point is, don't be afraid to check with some of them. Probably the small local guys, not the big chain stores.
Old 09-15-2018   #4
Top Toy
Top Toy's Avatar
Check with the Vette Doctors on Long Island.
Sent from my HTC U11 using ZR-1 Net Registry mobile app
'95 ZR-1, aqua/gray, #167
368 LPE/Haibeck, Web cams, Stainless Works headers, B&B Fusion exhaust, 18" Fikse wheels, Alcon brakes, lowered. 491 SAE RWHP.
Top Toy is offline   Reply With Quote
Old 09-16-2018   #5
rkreigh
hi phil
I wonder if Lloyd has done these. The urban myth is that the dual mass can't be surfaced, and also you can't turn the factory crank.
I understand the challenges, but with the price of the dual mass it seems like this would be a great way to go.
95 390 LPE ZR1 (505 rwhp)
Old 09-16-2018   #6
Jagdpanzer
Jagdpanzer's Avatar
No doubt Lloyd could do it. He has a nice flywheel surface grinder.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-19-2018   #7
stuntmanmike
Who is Lloyd?! Thanks!
Old 05-21-2019   #8
spork2367
The factory crank is nitrided. You would likely end up with insufficient case depth that would require re-nitriding.
