09-09-2018 | #1 |
Bad Leak
I went to an autocross today. After I parked the Z in the garage, I noticed a pretty large puddle underneath. It was a 1.5 hour drive home. I don't know how much it leaked on the way. The fluid was clear and thicker than water. It also had a hint of yellow. It must have come out faster since the puddle was formed in only a few minutes. By the time I looked underneath the car, it was dripping once every 10 seconds. I put a container under there and it appears to still be dripping after two hours. The only difference is that the drips actually look clear like water and isn't thick anymore. I've circled in red where it was dripping from. This is on the passenger side close to the side vent in front of the passenger door. The engine looked completely dry from the top. Any idea what kind of fluid this is? Unfortunately, I have a non-refundable track day scheduled for Tuesday. At this point, I'm not sure if it's even safe to start the car and drive to the mechanic. Any thoughts would be appreciated.
1991 ZR-1 #405 (white/black with blue pin stripes) |
09-09-2018 | #2 |
Re: Bad Leak
Water from AC evaporator.....removing heat and humidity from the air.
If that be the case......it is normal and NOT a leak......just defrosting the Evaporator Thicker than water is still a question??? Could be windshield wiper fluid but still...thicker than water is a question??? You can smell antifreeze easily Check all fluid levels just in case....Power Steering, Brake, Coolant overflow, and engine oil.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-09-2018 at 11:33 PM. |
09-09-2018 | #3 | |
Re: Bad Leak
09-09-2018 | #4 | |
Re: Bad Leak
Coolant overflow......plastic container under passenger head light. Power Steering......drivers side top front of engine near alternator. Clutch is actually under ECM (loosen ECM nuts and flip up and there is the clutch fluid) which should be checked at times also. Just a complete Fluid Check nothing to do with your "leak".....Transmission and Differential are sealed but you can remove the fill plugs and oil should drip out (that be full). I have a drain plug in differential and you do not Post 3 - LT5/ZR-1 Fluids
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-10-2018 at 12:00 AM. |
09-10-2018 | #5 |
Re: Bad Leak
Ok. I checked the power steering, brake, and coolant overflow.
Steering (looks ok to me): Brake (levels are near the max): Coolant overflow: The cap was very loose, like it was just sitting on top of the container. I could also see that the top of the container was wet. Could it be the coolant? Is coolant thick? One odd thing is that the coolant cap/dip stick stank. The paper towels I used to mop up the fluid on the ground did not.
09-10-2018 | #6 |
Re: Bad Leak
Your fluids look fine...…I am assuming oil dip stick is fine
I am guessing a bit but I think you have mostly water from the AC which is normal if you ran the AC. You may have some other oils here and there but from puddle size...that is typical AC. And that AC water is from humidity inside the vehicle and nothing to do with loss of any fluids Do check that clutch fluid sometime under ECM just in front of drivers side fire wall. Many do not even know that exists
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-10-2018 at 02:10 AM. |
09-10-2018 | #7 | |
Re: Bad Leak
I'm with Cliff (Dynomite) on this one and suspect just water from the AC and maybe some other residual coolant from the reservoir/loose cap you pointed out. Was your coolant temperature okay during the day and coming home? You might want to also check your coolant cap to ensure its holding pressure (off the top of my head I thought ours are 17lb caps?). You should top off your brake fluid too. I'll send you a PM. Best wishes.
09-10-2018 | #8 |
Re: Bad Leak
I agree w/ Cliff n Kraig, but I have an observation and a question:
I noticed some streaks from the coolant overflow cap. However, they may be old, and the coolant level on the dipstick is pretty close to normal for a COLD motor. ("pretty close", i.e., maybe a tad higher than the normal "cold" level would be IF/WHEN the motor is totally cooled off (i.e., not run over night.)). That 2nd photo = ?? Not sure what we're looking at. Is that a picture of a stain on the floor? Or, if not, what are we looking at? Just to add, dripping clear water from that spot (pictured) lines up exactly with the AC heat exchanger and pretty far away from any source of any other liquids, except coolant which would indicate the heater core or a connections thereto was leaking. BUT! In that case, the 'puddle" would NOT be clear - would be hard to mistake it for anything but coolant. Like I said - I agree w/ the others, from what you've said so far.
09-10-2018 | #9 |
Re: Bad Leak
I also agree but would still check around the high fill tank with a flashlight and just be sure. I believe you have a sensor and a few lines on it plus the cap. Also check the passenger carpet.. Just to be sure. .
09-10-2018 | #10 |
Re: Bad Leak
Call around and see if a local auto parts store has a coolant system pressure tester. That is the best way to confirm your cooling system is not leaking.
If you do have a cooling system issue, you may not get many laps tomorrow. On a side note, do you know how to see your cooling system temperature in your console display? That might be useful so you can keep a close eye on coolant temps. I forget the exact steps but they're probably on Marc's ZR1 Specialist's web site.
Russ McBride, [COLOR="Red"]Car Sold 8/2020[/COLOR] #1635, Marietta, GA USA, 1991 ZR-1, #766 (bought 1/1/2015) MS3-Pro, OBX, SW X-Pipe, Borla, Hurst, SLP, Goodyear F1 GS-D3, Kenwood. HOTB 2016Q3 [IMG]http://zr1.net/forum/picture.php?albumid=316&pictureid=2873[/IMG] [IMG]http://zr1.net/forum/picture.php?albumid=336&pictureid=2985[/IMG] |
