Old 09-08-2018   #1
Reichert
Default Weird "Y" air duct under steering column
I'm under the driver's side dash area for reasons (also on a quest to add an antenna switch) and I found a very odd ventilation duct "Y" extension just sort of stuck in place under the steering column, into where the driver's air vent exits. The part has mounting screw holes that are not used, and also looks like it should be connected to something else. Take a look and let me know what you think.
-Stephen
1990 #2288
Reichert is offline   Reply With Quote
Old 09-08-2018   #2
BlackZR1
BlackZR1's Avatar
Default Re: Weird "Y" air duct under steering column
A couple years ago I took some pictures when I was in that area.
These should help. My car is a 1990.
Roger
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Full-time secondaries, 4.10 gears, C-beam plates, ported top end
BlackZR1 is offline   Reply With Quote
Old 09-08-2018   #3
Reichert
A, great, that makes much more sense now. I will install in correctly this time! Thanks.
Sent from my moto g(6) play using ZR-1 Net Registry mobile app
-Stephen
1990 #2288
