07-27-2018 | #1 |
90 ZR1 Wont start
Hi
I just sold my 1990 ZR1. Car had just over 5000 miles. I never had a problem with it. New owner drove it home then called me saying the car will not start. Everything comes on when turning the key but will not crank. Security light comes on and goes out. I only have one key so He cant try another. Im thinking it has something to do with the theft system. Any one ever had this issue? Thanks,Steve |
07-27-2018 | #2 |
Re: 90 ZR1 Wont start
Clutch to the floor ? Low battery ? could be a number of things ....
07-27-2018 | #3 |
Try jump starting it, simplest issue would be a low battery or ask him to push start it, turn key to on, call a couple of friends push it and pop the clutch in 2nd. If it starts the problem most likely is in the starting circuit or starter. After that follow FSM procedure for no start.
07-27-2018 | #4 |
When I had my first zr-1 delivered, I drove to the gas station to fill up the tank.
When I got back in the car would not start. Turned out the floor mat rolled up under the clutch pedal and it was not going all the way to the floor. Good luck.
07-27-2018 | #5 | |
Does the starter Solenoid move (is there a click and reduction in voltage by diming lights for example)? If so.....that no start issue will be intermittent until you recondition the Starter Solenoid points. In Emergencies the Z is very easy to push start by hand in second gear pop clutch with key on (as 32valvesftw suggested above).
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-27-2018 at 11:37 PM. |
07-30-2018 | #6 |
It could be a number of things but it is his car now.
Tell him to get on here.
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. Last edited by phrogs; 07-30-2018 at 12:29 AM. |
07-30-2018 | #7 |
Yup!
