Old 07-17-2018   #1
C4CAMS
Default Intake Duct Alignment?
Forgive me if I'm using incorrect terminology:
I'm looking at a '90 with 83k miles. There is a noticeable misalignment between the engine intake and the plastic air filter ductwork, as shown by the S-bend in the flexible duct just ahead of the engine intake. Every other LT-5 I've seen looks well aligned in this respect. This caught my eye and the owner has no explanation. Injectors have been replaced. The plastic parts looked to be mounted correctly above the radiator. The engine didn't seem to be out of position (I looked down past the valve covers on both sides) and it drove well. I thought maybe an engine mount might be worn, but that is usually a noticeable problem while driving.
Anyone else seen this? Should I be concerned?
C4CAMS is offline   Reply With Quote
Old 07-17-2018   #2
efnfast
Default Re: Intake Duct Alignment?
I would be concerned
Old 07-17-2018   #3
Vette73
Check the easy things first.....Remove duct, make sure its not damaged or warped..Make sure its straight......Remove air filter housing, check alignment holes, maybe somebody retapped them? Put everything back straight if possible.....I have never seen that..
Vette73 is offline   Reply With Quote
Old 07-17-2018   #4
Concur......it seems looking at the stencils on the radiator cover.....they are in line correctly with the air filter housing. Either the whole radiator is shifted or the engine is rotated or moved to drivers side. That is definitely not correct alignment.
Old 07-17-2018   #5
G8nightman
G8nightman's Avatar
I seen that on a car that was in a accident before
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 07-17-2018   #6
onethumb
I'd want to get that up on a lift and look underneath for damage.
If the seller is not trying to hide something, they should be agreeable to a pre-purchase inspection by a mechanic of your choice. Might be the best $150 you ever spend.
onethumb is offline   Reply With Quote
Old 07-18-2018   #7
efnfast
Oh, and welcome to the forum.
Old 08-01-2018   #8
onetinsoldier
Check inside the drivers door near the hinges , if theres a vin plate there , it may be a rebuilt car . Check the title to see if its a salvaged car .
onetinsoldier is offline   Reply With Quote
Old 08-01-2018   #9
Karl
Karl's Avatar
The engine looks like it is tilted on the driver's side. If not a bad motor mount or simple fix I would pass that car up.
Easy way to check is measure the height from the rear of the plenum with the weather stripping on the windshield.
Good luck.
Old 08-01-2018   #10
Ccmano
The engine is sitting low in the back too. My money is on engine mounts. A very common issue. This one bad though. I have speculated that most cars that have not yet replaced the mounts are actually driving around on broken mounts.
H
Tags
air filter, intake
