Old 07-12-2018   #1
KPW
KPW's Avatar
Default A/C-related Squeal (Belt?)
Hi All -
I've noticed that when I first turn the A/C on, I get a squealing noise when I start to drive. Usually only lasts for the first 50ft or so. Most obvious in 1st or Reverse as I let the clutch out.
A/C seems to be functioning well (compressor seems to rotate OK by hand)...belt is new in the last two years (Continental Poly-V).
Has anyone run into this before? My feeling is that it's probably more belt than A/C, but strange that it only squeals when the A/C kicks on and at low RPM.
1991 ZR-1 #1438 Black/Black & Red
KPW is offline   Reply With Quote
Old 07-12-2018   #2
Ccmano
Ccmano's Avatar
Default Re: A/C-related Squeal (Belt?)
Most likely the belt. Make sure you have the right belt. Not everyone has the correct spec on the belt.
http://www.zr1.net/forum/showthread....highlight=Belt
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 07-12-2018   #3
KPW
KPW's Avatar
Aha. I think I remember having the 80.5 at some point. I'll double-check what's on the car and what my spare is. Thanks for the tip.
Old 07-13-2018   #4
My Billet Aluminum Alternator Pulleys are just a tad larger in diameter than the stock alternator pulley.
The belt lengths I use now ARE 80.5 inch outside length....
I install the belt by slipping the back side of the belt onto the smooth Billet Aluminum Water Pump Pulley last.
Old 07-13-2018   #5
onetinsoldier
You may want to check the ac clutch bearing . I had one go bad and press against the snap ring , it cut off the snout on the compressor and trying to find a replacement part for a zr1 is about impossible !
onetinsoldier is offline   Reply With Quote
Old 07-13-2018   #6
DITTO (there, Hans, you see it again!)
I wuz gonna mention the clutch and or the bearing.
NOTE: If you first spritz a little water or windex on the belt with the engine running, and then turn on the AC, if there is no squealing yet the AC compressor still turns normally, chances are it is the belt and/or the belt tensioner. If the belt ribs display cracking - for sure the belt is in need of replacement - regardless of anything else that might need attention...
A Mechanic's stethoscope is another way to find out if it is a bearing or not. But, first pull the diaphragm with the metal probe from the rubber hose. Use the open end of the rubber hose to probe for the squealing - works much better than the metal probe in some cases (a trick I leaned from Marc Haibeck).
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
