Old 07-10-2018   #1
Scarabexc
Default 1994 water pump replace advice
Changing my Water pump this weekend, I have a genuine GM pump and gasket, just wondering if there are any tips or advice from someone who has done this,,,
Thanks
Scarabexc is offline   Reply With Quote
Old 07-10-2018   #2
KPW
KPW's Avatar
Default Re: 1994 water pump replace advice
Pay attention to the bolt locations. There are a lot of different bolts on these things, so I used a cardboard template to keep track of each one’s position.
On the coolant refill, it might be worth poking around the forum to find your favorite method of avoiding air pockets.
Other than that, I found it pretty straightforward. Enjoy!
1991 ZR-1 #1438 Black/Black & Red
KPW is offline   Reply With Quote
Old 07-10-2018   #3
Jagdpanzer
Jagdpanzer's Avatar
Thanks
I would like to have your old pump if you don’t need it.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-10-2018   #4
Scarabexc
Thank you
Old 07-10-2018   #5
Young1
Young1's Avatar
What are you working on with water pumps, Phil?
Old 07-11-2018   #6
Marc Haibeck also rebuilds the WPs.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
