Old 07-04-2018   #1
5ABI VT
Talking My 1 Minute Plenum pull on video !!
Editing a full video for youtube I made this one 1 minute just for Instagram. Its fast forwarded of course but I thought Id just record it this time. Took an actual 19/20 mins taking my time with just a few hand tools.
https://youtu.be/Ols5xKhZhks
Old 07-04-2018   #2
Default Re: My 1 Minute Plenum pull on video !!
Nice.....I could not tell if you have TB coolant blocked but in any event....you covered ALL the steps including removal of the MAP bracket before you disconnect the main DIS connection
Everyone should take a quick look at your Fast Forward Plenum Removal Video as it is very informative
Old 07-04-2018   #3
RussMcB
Very cool! Thanks. Enjoyed that.
Old 07-04-2018   #4
5ABI VT
Everyone should take a quick look at your Fast Forward Video as it is very informative
Thx !! and yes forgot to mention the coolant is blocked at the Injector housings so it does help for an easier ‘dry’ removal . I was debating on making a full detailed video.. maybe I can do it later with a head strap mount and talk as I do it. I’m sure I could easily knock it down to 15 mins taking my time with it fresh in my mind. So much easier than working on my Lt1 it motivated me to record it
Old 07-04-2018   #5
BlackZR1
BlackZR1's Avatar
Excellent video, Thanks!
You seem to have a little more slack in the DIS harness than I do. After the plenum is unbolted I need to elevate the plenum with a few wooden blocks to get my hands underneath to remove the DIS connector.
Coolant block-off is definitely the way to go.
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Full-time secondaries, 4.10 gears, C-beam plates, ported top end
BlackZR1 is offline   Reply With Quote
Old 07-05-2018   #6
G-Sting
G-Sting's Avatar
You work fast!
Nice video. Thanks for doing that!
'94 ZR1 LT5 - Dark Red Metallic
'79 L82 4-speeds of fun
'96 LT1 Borla, H-pipe, TB, CAI (Sold)
"An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered." -- G.K. Chesterton
G-Sting is offline   Reply With Quote
Tags
diy, intake, lt5, plenum pull
