Old 06-24-2018   #1
aafc
aafc's Avatar
Default display shows no data
Well i was going to take the car for a ride this morning but when i started
the car the display showed no data. Now the car started and ran fine, at one
time the display showed all correct data. The next time all i get is a blank
display , i cannot display any codes. After checking the service manual i see
that the CCM will show code 31 no display or data.They say remove cluster
and check for B+ short to gr. It could be the CCM causing the tbl. So should
i pull instrument panel first and go from there. Checked ECM no tbl codes.
Either way i'll have to pull something out.
Thanks
1990 #2546 white/black
one of a few auto (4l80E ) eq. ZR-1;s
aafc is offline   Reply With Quote
Old 06-24-2018   #2
Ccmano
Ccmano's Avatar
Default Re: display shows no data
If it’s just the LCD display, gauges are working, Check with these guys, the instrument cluster is known to have issues.
www.Batee.com
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 06-24-2018   #3
aafc
aafc's Avatar
I have used there services when my LCD had fuzzy, light display. changed the
orange/yellow film . What i have is all the numbers were lit up and then none.
i will pull the display and check step one for code 31 in the CCM diag.I will
check the contacts to instrument display . Batee told me that i could
have dirty connections to the display. I will let you know what i fine.
Thanks
one of a few auto (4l80E) eq.
ZR-1's
Old 06-25-2018   #4
aafc
aafc's Avatar
Update
Removed instrument display and cleaned the contacts on the LCD contacts
with a rubber eraser. Reinstall and display is operating as they should.
Well as long as steering wheel is down i'll do the the fog light up grade to
work with the new LED headlights.
Thanks
1990 white/black #2546
one of a few (4L8OE) eq ZR-1's
