06-22-2018 | #1 |
Is this thermostat correct?
The box says Stant 14068 which is the correct number. But thermostat itself doesn’t look like the ones I’ve always seen. Interestingly Kurt White shows this exact thermostat on his listings. I thought this might be mispackaged.
H
06-22-2018 | #2 |
Re: Is this thermostat correct?
06-22-2018 | #3 |
No that is not the correct T-stat and it is not a Stant #14068. I have found wrong T-stats & PCV valves in the right PN box, many times.
This is what a Stant 14068 thermostat looks like. Sent from my iPhone using ZR-1 Net Registry
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 06-22-2018 at 07:09 PM. |
06-22-2018 | #4 | |
H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. Last edited by Ccmano; 06-22-2018 at 08:15 PM. |
06-23-2018 | #5 | |
Thanks for the thought Hans, but we haven't had any in awhile. Stant discontinued them. I haven't taken the time yet to cover a replacement for this part.
