Old 05-15-2018   #1
Tripler
Tripler's Avatar
Wink ZR-1 Suspension
Hey guys and gals . I have been curious about the suspension in the ZR-1 specific cars . Do they have a slightly different suspension design than the stock C4 Corvette ? Or are they basically the same as any other FX3 suspension option in a C4 Corvette ?
Trip
Tripler is offline   Reply With Quote
Old 05-15-2018   #2
Default Re: ZR-1 Suspension
Spring rate might be a bit different, but they are the same
Old 05-15-2018   #3
Some have the "coil-over" system installed replacing the cross-over spring which some swear by and a few SWEAR AT!
I know Robert DeMarco speaks well of the coil-overs, but our local Bob Gillig didn't like them and reverted back to the stock springs. I value both of their opinions so that leaves me
Ami's Z has coil-overs, and mine does not. Someday I'll get up to NW IL and drive some of the twisties around Galena with her car. THAT SAID, I've NO complaints doing the DRAGON etc., on several MRs now with the FX3.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 05-15-2018   #4
I am one that likes the feel of the car with Coil overs.. Rides quite well and works great with the FX3..
But all the stock components are the same essentially from narrow to wide body C4s.. with exception of some early 1990 ZR-1s with steel 1/2 shafts
but springs codes will vary, I know the front spring is different but not certain on the rear.
Old 05-15-2018   #5
Tripler
Tripler's Avatar
I found this article tho .
www.ZR1.net
The nosebleed cost of the ZR-1 wasn’t just because of the LT5 engine. The ZR-1’s body widened from the doors back in order to cover what was then considered ultra-wide rear tires. Wheels, tires, and suspension were all upgraded to handle the 125-horsepower difference between the base 250-horsepower L98 and the LT5’s 375-horsepower. Corvette sales were almost half what they’d been in the mid-80s. Had the economy been better, and if Chevrolet would have been able to order more engines from Mercury Marine, the price would have come down.
Old 05-15-2018   #6
Ccmano
Ccmano's Avatar
With the exception of the half shafts (aluminum instead of steel) and the brake lines (longer rear lines I believe) the components are all stock and were available on the standard C4. That said, they were the high end components of their time. FX3 shock system, J55 brakes, specific spring rates (that changed over the years) and sway bar thicknesses. Everything is interchangeable with a standard C4.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 05-15-2018   #7
Tripler
Tripler's Avatar
H
Interchangeable yes but still , would the ZR-1 specific suspension have been considered its own suspension passed on to other type C4 Corvettes ?
Like GM adding optional extras to the regular C4's ? Is that what you are saying ?
Also , did Lotus design the suspension for the ZR-1 or was it just modded by GM for the extra width of the rear tires and increased engine weight of the LT5 ?
Old 05-15-2018   #8
Ccmano
Ccmano's Avatar
Originally Posted by Tripler View Post
Interchangeable yes but still , would the ZR-1 specific suspension have been considered its own suspension passed on to other type C4 Corvettes ? Nope, the suspension design started with the 84’
Like GM adding optional extras to the regular C4's ? Is that what you are saying ? Nothing, everything on the ZR-1 was available previously
Lotus had nothing to do with the suspension, only the engine. It was all GM, weight of the engine was not a factor in suspension design, only suspension specifications.
Answers above. Don’t confuse suspension design with suspension specification.
H
Old 05-15-2018   #9
Tripler
Tripler's Avatar
Alrighty then . All cleared up . Thankyou very much Ccmano and you other guys for the responses .
Have a good one and hope to see some of you in BG this Wednesday ...
Old 05-15-2018   #10
USAFPILOT
USAFPILOT's Avatar
there was the Active Suspension car! that was ZR-1 only, and 1 of 1.
