Go Back   ZR-1 Net Registry Forums > General > For Sale & Wanted (General)
Old 04-28-2018   #1
ZR-1Mikko
ZR-1Mikko's Avatar
Default 1993 Corvette Coupe LT4 383 Stroker Supercharged, NOS, Extra engine Extra Drag Tires
10 second Vette build for Drag racing, but still street legal and street drive-able. Clean Las Vegas based 1993 Corvette with supercharged 383cid LT4 motor with only 70k miles on the chassis.
Black leather interior in perfect condition with Corbeau seats, full roll cage, 5-point seat belts and fire extinguisher. All stock accessories are still on car including air conditioning (not charged). This Vette has always been garaged and cared for inside and out as you can see in the pictures. It is currently street drive able, but would need to have the head gaskets to be replaced for WOT track racing.
Also included stock LT1 engine complete with 50,000 miles, Procharger P600 SUPER CHARGER, BBK throttle body, 24 LBS fuel injectors. I have all documents available for all parts.
Additional Weld racing drag racing rear wheels with ET Street tires on them
Please let me know if you have any additional questions or would like additional pictures.
List of mods made:
CAR……………………………………… …………….1993 CORVETTE LT4
RACE WEIGHT…………………………………… …3333LBS
ENGINE…………………………………… ………….LT4 383 CID.
BLOCK……………………………………… …………….LT1 4 BOLT MAIN
COMPRESION RATIO……………………………….9:2
HEADS……………………………………… ………………PORTED LT4 2:02 / 1:625 VALVES
INTAKE MANIFOLD…………………………………..L T4, PORTED AND PORT MATCHED
CAM……………………………………… ………………CRAIN CAM HYDALIC ROLLER 222 / 230
DURATION AT .050, .559 / .580 LIFT
ROCKER ARMS……………………………………… CRAIN GOLD RACE ROCKERS 1.60 RATIO
PISTONS…………………………………… …………..J E FORGED PISTONS, 4.040 BORE
RINGS……………………………………… ……………….CHILDS & ALBERT Z-GAP
CRANKSHAFT………………………………… ………EAGLE 4340 STEEL. 3.75 STROKE
BLOCK……………………………………… ………………..ARP MAIN & HEAD STUDS
RODS……………………………………… ……………..CARRILLO 6” RODS
ENGINE BALANCE……………………………………. .INTERNALLY BAL. BY KELL’S MACHINE SHOP
BALANCER…………………………………… ……………ATI CUSTOM BUILT WITH ADDITIONAL 8 GROOVE FOR SUPER CHARGER
SUPERSCHARGER……………………………… …ATI PROCHARGER D1SC @ 21 PSI BOOST
PULLY……………………………………… …………….REICHARD RACING PULLY, CUSTOM BUILT 8 GROOVE, FOR D1SC PROCHARGER
INTERCOOLER………………………………… ………SPEARCO CUSTOM BUILT AIR TO AIR
BLOW OFF VALVE…………………………………..ATI 1.5” RACE VALVE
THROTTEL BODY…………………………………….EDE LBROCK / BBK 58 MM BILLET
INJECTORS………………………………… ………….BOSH 72 LBS / HR.
FUEL PUMP……………………………………… …AEROMOTIVE A1000 SUMP MOUNTED / AEROMOTIVE FUEL PUMP COTROLLER & FUEL PSI CONTROLLER
OIL PAN……………………………………… ……….CANTON 8 QT. WITH TRAP DOORS
OIL PUMP……………………………………… ……MILDON HIGH VOLUME PUMP
RADIATOR…………………………………… ……….UPGRADED ALUMINUM
ENGINE MANAGEMENT ………………………..FAST SYSTEM ELECTRONIC, LAP TOP PROGRAMABLE
INGNITION………………………………… ………MSD 6AL. MSD BLASTER HVC. MSD WIRE SET
DISTRIBUTOR………………………………… ……..MSD PRO-BILLET. CUSTOM MOUNTED AT REAR OF INTAKE MANIFOLD
EXHAUST SYSTEM………………………………..1.75 HOOKER LONG TUBE CERAMIC COATED HEADERS, 3” BILLY BOAT EXHAUST SYSTEM
TRANSMISSION……………………………… …700R4, SR7 PERFORMANCE, SHIFT KIT
TORQ CONVERTER……………………………….3000 RPM STALL
DRIVESHAFT………………………………… …..ALUMINUM, BALANCED, PERFORMANCE U-JOINTS. DRIVE SHAFT & ½ SHAFT SAFTY LOOPS
DIFFERENTIAL……………………………… …..DANA 44. 3.33 GEAR RATIO
BRAKES…………………………………… ………..DRILLED / SLOTED ROTORS, CERMIC PADS
GAGES……………………………………… …………..PILLER MOUNTED FUEL & BOOST
NOS……………………………………… ……………NOS SYSTEM, WET 150 HP, LIGHTED PURGE VALVE, BOTTEL HEATER, BLOW OFF VENT TUBE
CAGE……………………………………… …………5 POINT ROLL CAGE WITH SWING OUT DRIVER SIDE BAR
BELTS……………………………………… …………….G FORCE 5 POINT WITH QUICK RELEASE
WHEELS…………………………………… …………WELD WHEEL REAR RIMS & MT STREET SLICK
DYNO REAR WHEEL 12-17-2011…………….. 782 HP / 746 TORQ
Asking $14,500
I'm posting this for a friend of mine, but I can answer any questions you may have. Feel free to pm me if you would like to find more details about the car by phone.
If you don't put the miles on it, someone else will...
ZR-1Mikko is offline   Reply With Quote
