Old 03-04-2007   #1
zr-1assassin
zr-1assassin's Avatar
Default anyone know where to get vacuum lines for the Z
NEED THE VACUUM LINE THAT CROSSES OVER THE MOTOR FROM DRIVERS SIDE PLENUM TO PASS. SIDE PUMP AT THE FRONT OF THE CAR. ANYONE KNOW WHERE TO GET THESE. CHECKED ECKLERS,MID-AMERICA AND CORVETTE CENTRAL, COULDNT FIND ANY. THERE IS A KIT ON EBAY FOR $300.00 BUT ALL I NEED IS THE ONE.
zr-1assassin is offline   Reply With Quote
Old 03-05-2007   #2
Jeffvette
Default Re: anyone know where to get vacuum lines for the Z
www.whiteracingproducts.com
Old 03-05-2007   #3
Z Factor
Z Factor's Avatar
Lightbulb Re: anyone know where to get vacuum lines for the Z
In addition to the source posted, you can contact P & G. They can normally get what you need at reasonable prices, certainly better than the dealer. Their number is 1.888.870.0280 x214
https://www.partszoneonline.com/index.php
Old 03-05-2007   #4
hpbadger
hpbadger's Avatar
I will be checking these sources myself as I broke a vacuum line yesterday
Anybody have any luck patching up broken plastic lines? fobs? tape?
hpbadger is offline   Reply With Quote
Old 03-05-2007   #5
tccrab
tccrab's Avatar
The "plastic" tubing itself is a semi-rigid nylon tubing that's available from Legris. I can't remember the exact size (3mm ???), but it's metric.
Here's a link to their website:
http://www.legris.com/legris_com/Vis...BM&gr=09&fa=01
You can buy similar tubing from most any Pneumatic supply house. Look in the yellow pages under Pneumatic.
TomC
'90ZR1 #792
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 03-06-2007   #6
hpbadger
hpbadger's Avatar
TomC
'90ZR1 #792
Thanks!
hpb
