04-04-2018 | #1 |
HELP - LT5 Idle Air control connector
Well my bad, I broke the lock portion of the harness connector to the Idle Air control. Does anyone have a source for one of these 4 wire connectors? I think it is a weatherpack.
Also is there a trick to remove the wires without cutting and splicing in a new connector? Thanks in advance, John
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
04-04-2018 | #2 |
Re: HELP - LT5 Idle Air control connector
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-05-2018 at 12:04 AM. |
04-04-2018 | #3 |
Hi John, try searching for GM 12126487. I believe that is the IAC connector part number. I also show Delco PT757.
Here is a tool on amazon that will help: https://www.amazon.com/Lisle-56500-T...atherpack+tool If that link doesn't work, search for Lisle 56500. Jim
04-04-2018 | #4 |
It's a Pull To Seat Metri-Pak 150 I'm quite sure and the empty connector shell that is in the FSM doesn't seem available to create a new. You would have to actually cut the connector off insert the wires through the connector add terminals and seals then pull back towards you. I don't believe unless '90 was very different that would be the assembly process. A cut/splice of a connector that will work isn't an issue. I believe I can give you a couple numbers. If you bought the mentioned connector you could possibly use only that shell, buy terminals, seals and reassemble.
If your intention is the NCRS thing I'd think it would be good to have the real deal. I'll try to sort an empty connector terminals etc if you'd like! ***I believe I've found a suitable 'empty shell' for you if you're interested. Last edited by WVZR-1; 04-04-2018 at 08:01 PM. |
04-04-2018 | #5 | |
https://rover.ebay.com/rover/0/0/0?m...2F273107875470
04-04-2018 | #6 | |
04-04-2018 | #7 | |
H
04-05-2018 | #8 | |
I did get a GM 12126487 but it came with the pigtails. My preference is not to cut the harness, I'd like to find the bare connector for the repair. Thanks to all for the sources. John
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) Last edited by jrd1990zr1; 04-05-2018 at 09:00 AM. |
04-05-2018 | #9 |
Even with an empty 'correct' shell you still have a cut required to use it. This is an assembly guide for a 150 "Pull to Seat'. The packages that are mentioned in some of the links suggested are 150.2 P2S NOT 150.
Here's an assembly guide of a 150 P2S. I did send you an email. https://www.mwignitions.com/pdf/Pull2seat.pdf You have an 'original' 12126487 now? Are all of the wire leads WHITE? If you have a vernier measure the total length of just the shell part of the connector. I believe I can ID it as to being original 150 or if it's maybe a later 150.2. Measure the length of your busted one as a comparison. Last edited by WVZR-1; 04-05-2018 at 09:08 AM. |
04-05-2018 | #10 | |
I have a caliper and will measure the shell length and post back. Replied to your e-mail. Thanks again, John
