![]() Join Date: Oct 2017
Do you ever get carried away when working on your car?
I decided a couple of weeks ago I was going to find & fix the small oil leak I had noticed since I had the car. Got the car up, took everything off to gain access to all the pan bolts. Tightened all of them (replaced one front pan bolt that was missing) and also the oil pressure regulator bolts. (It is not leaking now ![]() While under the car noticed the clutch slave cylinder appeared to maybe be leaking a bit. Better change that. Oh yea, have been intending to replace the back up light switch. Got that done. While the slave cylinder was out decided I probably should change the line from the clutch master cylinder. Good call. It is dated 07/89!. Well, since I have the battery out, might as well remove the battery tray and make sure the air bag sensor is well grounded. Hey, the back side of the wheel well liner is not real clean, let's take it off and clean everything up real well. Might as well take off the middle section also. Just 3 more bolts. Looks like the back side of the rocker panel might be dusty. Can't have that!! Got that sucker off too. Now I have noticed that all of that nice aluminum on the suspension is not really shiny. Is that the jar of Mothers Aluminum Polish calling my name??? Geeze!!! ![]() Attachment 7137
Kenny 1990 #442 ![]() |
Well, as a newbie ZR-1 owner you have now discovered the “While you’re there...” phenomena that surrounds our cars. Congrats.
Don't worry, you're now caught in a spiral leading to ZR-1 splendor and glorious enlightenment. Happens to a lot of us.
Carried away never... lol.
Hahaha you have no idea
![]() Dave Hetrick |
#6 | |
![]() Join Date: Aug 2015
Gotta love the tub of LT-5 parts! Looks like a great place to hang out[emoji41]
Sent from my QTAIR7 using ZR-1 Net Registry mobile app |
![]() Join Date: Feb 2011
#9 | |
"Corvettes are Red". "The Red ones are the Fastest!" ETC. Suprisingly, this is just the second Red corvette I have owned, and the other one was a 1990 ZR-1 just like this one !!
#10 |
![]() Join Date: Apr 2004
Its called bonding time
