Old 03-16-2018   #1
zr1assassin
Default Installing headers....block off EGR?
Hey guys getting ready to install a set of headers(on 92'), do you have to block off the EGR? If so what's everyone using for an EGR block off plate?
zr1assassin is offline   Reply With Quote
Old 03-16-2018   #2
HAWAIIZR-1's Avatar
Default Re: Installing headers....block off EGR?
You don’t have EGR to worry about on MY 92. I believe only 93-95 MY does.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 03-16-2018   #3
zr1assassin
Awesome! Thanks
Old 03-16-2018   #4
HAWAIIZR-1's Avatar
Originally Posted by zr1assassin View Post
Awesome! Thanks
You’re welcome. There are some posts you’ll want to check out to help you out and make the mod go smoother. Good lessons learned here. Check with Paul Workman for oil dipstick bracket. There are thoughts about bolts to use and extensions or not for O2 sensors, etc. Dynomite (Cliff) will probably post his link to tips and tricks with how to. Best wishes.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 03-16-2018   #5
efnfast
O2 sensor. Dipstick bracket. Steering column interference. Header bolts. Ceramic coating.
Old 03-16-2018   #6
zr1assassin
I have to get the dipstick bracket and the O2 sensor extensions but I have header bolts, not ceramic coating them and the steering column interference can be handled with a hammer
Old 03-16-2018   #7
jss06c6
I went with SW headers and exhaust. Only mod I needed to complete was to re - bend the oil dipstick tube and install O2 sensor extensions. You will, however, need to return to get your fuel maps correct.
Sent from my QTAIR7 using ZR-1 Net Registry mobile app
Old 03-16-2018   #8
Post 45 - Exhaust System Replace with Headers
Post 46 - Exhaust Headers Locking Bolt Tricks
Old 03-16-2018   #9
Ccmano
Originally Posted by jss06c6 View Post
You will, however, need to retune to get your fuel maps correct.
That part is important. Did headers on mine recently. Without cats it stunk to high heaven and backfired like crazy on deceleration. The retune eliminated the backfire, improved the stink (still there) and really improved power. I’m now adding cats back on.
H
Old 03-16-2018   #10
Jagdpanzer
Jagdpanzer's Avatar
Which cats did you decide to go with?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
