03-08-2018 | #1 |
For the '95 'only' guys and later ZF purchases
I was doing some research and came across this TSB/Campaign that would have been issued for cars #1 thru #61. Later affected? TBD I guess.
I don't believe I've ever seen it discussed before. Is it on the Registry? Don't know. If any one has a later 'blue tag' service transmission it could be an interesting read. This would only apply to the 'crash-thru' boxes. 95-C-16 ZF S6-40.pdf This TSB also issued for 'cold soak' hard shift 47-72-01 ZF TSB.pdf Last edited by WVZR-1; 03-08-2018 at 09:56 AM. |
03-08-2018 | #2 |
Re: For the '95 'only' guys and later ZF purchases
Thanks for sharing and an interesting read regardless.
