02-26-2018 | #1 |
Oil pressure guage jumping around.
This only happens at highway speeds,is this the sending unit going out and is it the sender on the oil filter housing?
02-26-2018 | #2 |
Re: Oil pressure guage jumping around.
I would change out the Dash Gauge Sensor......you did not say what the readings were?
Jerry's Oil Pressure Sensor Dash Gauge Easy to remove and easier to install. I think Channel Locks as it is like 1/4 inch pipe thread. 27 mm Open End wrench will fit also
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-27-2018 at 12:47 AM. |
02-26-2018 | #3 |
Thanks Cliff now where can I find the socket to remove it and where can I find the sender?
02-27-2018 | #4 |
Jerry's Gaskets for the Oil Pressure sender:
http://www.jerrysgaskets.com/search....sensor&x=0&y=0
02-27-2018 | #5 |
My 95 use to jump around and it was the oil pressure switch. The plastic part had come loose from the Big nut it connects to. Changed switch and had proper readings.
Good Luck. |
02-27-2018 | #6 | |
Removing Oil Pressure Switch TIPS Paul Workman removed the Oil Filter Adapter with great success to get at the Oil Pressure Switch
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-27-2018 at 01:32 PM. |
02-27-2018 | #7 |
Be sure to buy from Jerry. I tried two different ones acquired locally from nationwide retailers and both were junk. In both cases they had been calibrated incorrectly or not calibrated at all. The one I bought from Jerry worked properly every time. Jim
02-27-2018 | #8 | |
02-27-2018 | #9 |
I think I have replaced three of these on the 91 in 12 years. The failure rate is high on these. I remember the one time the gauge dropped to zero and I shut the car off immediately. The last two failures were the waggity needle failure.
03-02-2018 | #10 |
Thanks for the info everybody,I’ll have to get in touch with Jerry for the part and the socket.
