Old 02-04-2018   #1
efnfast
Default Tranny drain plug
Was going to change the tranny fluid, but not happy with the way the drain plug is not coming out. I want a new one in hand before I ruin the old one.
Where does one get these?
Old 02-04-2018   #2
efnfast
Default Re: Tranny drain plug
Kurt White is selling them on Ebay. Not hearing great things lately. Plus, $39 for the plug and $15 for shipping.
Old 02-04-2018   #3
WVZR-1
Your local VW dealer or perhaps Pelican. If ordered from a local VW dealer make sure they don't substitute a later that is 'spline drive' of sorts. They use both.
Old 02-04-2018   #4
Young1
Young1's Avatar
Heat it some with a propane torch. I bought the Allen wrench at napa. Then cut a piece off the wrench to slide into a short socket just the right depth to fit that shallow plug. This way it did not go sideways on me. The heat does the trick. First time they had been removed since built 27 years ago.
Steve Young
Second Owner
SOLD
SOLD
Old 02-04-2018   #5
I also grind the end of the tool hex nearly flat (grind away the chamfer) to engage all the depth of the plug. Mine came with quite a bit of chamfer. Helps to keep the tool straight in the plug.
Old 02-04-2018   #6
Young1
Young1's Avatar
Yep I did the same thing. Full engagement
Steve Young
Second Owner
SOLD
SOLD
Old 02-04-2018   #7
efnfast
Jerry, I checked your web site and didn't see any. Do you carry these?
Old 02-04-2018   #8
jss06c6
When you go back in, you might consider using ARP thread sealer. Works beautifully. Never have to worry about it sticking again. Using it on all plugs in my cars.
Sent from my QTAIR7 using ZR-1 Net Registry mobile app
Old 02-04-2018   #9
Yes. Thanks for that.
And, I've used Teflon plumbers tape - that and some Never-Seize (the latter on any plugs that must be removed periodically).
Grinding off the chamfer...good one!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 02-04-2018   #10
efnfast
When it comes time to remove it, yes I will grind off the chamfer. Lube? Seems it is covered in lube, aka gear oil.
