01-15-2018 | #1 |
Rear diff drain
Any down side to drilling and plugging the rear diff for fluid changes?
Anybody crack one?? Oh the horror. |
01-15-2018 | #2 |
Re: Rear diff drain
I used the drill and tap kit from Corvette Central, worked great, no issues.
Rich
01-15-2018 | #3 | |
Re: Rear diff drain
See item #4 LT5 Added Systems Original Photos provided by Scrrem with Red notes added Thank You Rich It is worthwhile to do if for no other reason you get a complete drain of the original Differential Fluid
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-15-2018 at 07:40 PM. |
01-15-2018 | #4 |
Re: Rear diff drain
Thanks Cliff, I've got all that stuff at home.
01-15-2018 | #5 |
Re: Rear diff drain
I wonder why it didn't come with a drain.
I added one via the kit a while back. I don't remember it being easy, but certainly not a big job. The "official" kit comes with a template to help you drill in the right location. |
01-15-2018 | #6 |
Re: Rear diff drain
Here's one I did using a pipe plug
01-15-2018 | #7 |
Re: Rear diff drain
This location of the drain plug is at the Lowest point inside the Differential
Original Photos provided by Scrrem with Red notes added Thank You Rich See item #4 LT5 Added Systems
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-15-2018 at 07:49 PM. |
01-15-2018 | #8 |
Re: Rear diff drain
Now if I could just fine those 1/8" anodized plugs I bought when I did my plenum......
01-15-2018 | #9 | |
Re: Rear diff drain
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-15-2018 at 09:47 PM. |
01-15-2018 | #10 |
Re: Rear diff drain
I think I have some around here. If not, I probably have a regular SS one's at work
