Old 01-10-2018   #1
Ccmano
Ccmano's Avatar
Default Tensioner and Belts beware...
So as part of the current winter project with items too numerous to detail, I changed the serpentine belt on the Z recently. Looking at various sources the recommended belt is 80.5 inches long. Available from various manufacturers and sources. I purchased a Duralast from Autozone. When I started the car afterwards I instantly noticed the tensioner making a rattling noise. Even got squealing when the A/C compressor kicked in. I thought, crap! You do one thing and something else goes wrong. Knowing that tensioners can be rebuilt I looked up the thread here in the forum, bought the parts and rebuilt the tensioner. From the looks of the inside it needed it. Excellent info as always. Here’s the link.
http://www.zr1.net/forum/showthread....ight=Tensioner
Something in the back of my mind reminded me there was a belt issue as well. I started searching and sure enough. There are several past threads on the matter which seems to come up every few years. Here’s one.
http://www.zr1.net/forum/showthread....erpentine+belt
Seems the standard quoted replacement belt length is 80.5 inches. Why, no one knows. The original belt measures 80.1969 inches. Belts are available in 80, 80.2, 80.25 and 80.5 inches. Apparently the much quoted Marc Haibeck recommends 80 inch belt to tighten things up a bit more. So I took his advice and purchased an 80 inch belt Dayco 5060800. After installation I must say there is a significant difference in the tensioner position. I have posted some pictures below.
My take away is this. If you have a weak tensioner, the 80.5 inch belt will show it quickly. The 80 inch belt may save you a tensioner rebuild for at least a while. On a side note there is also an alternator pulley diameter question that plays into this. Apparently replacement alternators have some variation.
H
80.0 inch belt
80.5 inch belt
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 01-13-2018   #2
Default Re: Tensioner and Belts beware...
H
80.5 inch belt
80.0 inch belt
Good 2 know. Thanks 4 the pix!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 01-13-2018   #3
PhillipsLT5
PhillipsLT5's Avatar
Great info
Old 01-16-2018   #4
billschroeder5842
billschroeder5842's Avatar
Thanks- who would have thought that .5 inch would make that much difference.
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
Old 01-17-2018   #5
I don't find that so surprising, Bill--After all, someone once said that size matters --Bob
