![]() Join Date: Jun 2013
Hello,
Does anyone have the part number for just the cap that goes on the fuel rail where you test fuel pressure? Thanks, Bill
LT5 Red/Red |
![]() Join Date: Jan 2015
FYI - I think an -4AN cap will screw on there.
Mine dropped down into the valley a couple of years ago. I think I had a blue anodized cap on there for a while, and later put a fuel pressure sensor there. Last edited by RussMcB; 12-29-2017 at 10:26 PM. |
Good information, thanks for your help!
Bill
LT5 Red/Red |
![]() ![]() Join Date: Nov 2007
When I went through that search a few months ago, until a kind soul gave me one, several suggested going to a local HVAC shop - it being an AN fitting.
Good hunting!!
![]() Join Date: Oct 2004
If you're near an ACD jobber or GM dealer you might try 214-1044 or 25532662. I've never tried this but I don't know why not. With whatever you buy be sure to check inside the cap for the o-ring seal. I think that generic -4AN caps may not have the seal.
If you try the GM I'd be interested if you post back and mention your thoughts. I've always intended to but haven't had the need so I never have. |
Feel free to correct me if I'm wrong, but that seal probably isn't super important. The cap is mainly to keep out water/dust, right? It's not holding fuel pressure in the rail. My hunch is, the AN cap wouldn't let anything in as long as it's on tight enough not to back off due to vibration.
Thanks again for the information. I ended up at Lowes and bought part number 40-4X P. For $2.00, I have a cap that will work although it isn't NCRS!
Thanks again, Bill
LT5 Red/Red |
Ah, 7/16-20 straight thread, 4AN.
Thanks for sharing. |
#9 |
![]() Join Date: Jul 2010
Theres another thread about this exact topic.
peace Paul ZR-1 Net Registry Member #1494 |
#10 |
![]() Join Date: May 2007
GM did not issue a part number for the metal silver cap used on the LT5. The cap was available in a service kit that included a new valve. The kit is PN 17112219 discontinued by GM.
