View Poll Results: Did you eliminate your Secondary Throttle Vacuum System? | |||
Yes. | 21 | 55.26% | |
No. | 17 | 44.74% | |
Voters: 38. You may not vote on this poll |
11-17-2017 | #1 |
Just thinking of eliminating my Secondary Throttle Vacuum System. Having some idle issues and I would like to eliminate that leak possibility.
I'm wondering how many of you guys eliminated that system. |
11-17-2017 | #2 |
Re: Did you eliminate your Secondary Throttle Vacuum System?
Sure did. Allowed injector housing porting to make the most out of 4" pistons and 3.75" stroke crank. LT5 runs flawlessly and never looked back.
Another benefit - 2ndary runners look clean like the primaries always. Last edited by secondchance; 11-17-2017 at 08:48 PM. |
11-17-2017 | #3 | |
I like that Power Key Option albeit I keep it on Full Power. That Full Power Option is very unique to the ZR-1s Kevin did a great "How To" write up on rebuilding the Power Key See Item #2 CMHSL LED, Full Power Key and Alternator Pulley Jerry some time ago had available complete secondary vacuum lines and rubber connectors for the 95' (for around $100 as I recall) but he ran out I guess which is not surprising for such a bargain
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-18-2017 at 08:52 PM. |
11-17-2017 | #4 |
All gone, GREAT!
11-18-2017 | #5 |
I did, but miss them when it is time to tell the story about the key. "That key is for this, but not anymore."
11-18-2017 | #6 |
Eliminated the secondary actuation pretty soon after buying the car. Never noticed anything detrimental because if it.
11-18-2017 | #7 |
Pulled mine out 8 yrs ago when I ported the top end. Runs great. No regrets!
11-18-2017 | #8 |
I did on my '95. Marc did the work as part of a 510 package. One caveat: When they are eliminated, the injectors are set to run at a 50% flow rate so if you turn off the power key (i.e., return to "normal") the car will run too lean as it would shut off the secondary injectors. (I think I explained that correctly but please chime in if I did not.) I removed the key from the car and put a keychain tag on it to remind a future owner of the situation. --Bob
2016 Long Beach Red Z06 #10281 "POPS Z" 1995 Polo Green #409 "WARP TEN"--Haibeck 350/510 package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts --Sold but still running strong 1993 Quasar Blue #161 "HIL KING" --Sold but still running strong, now with more than 120,000 miles 1967 Marlboro Maroon/Saddle Corvette Coupe 300 hp/4-spd --Sold a long time ago ZR-1 Net Registry Founding Member #95 NCM Lifetime Member Favorite Quote--Attributed to Mickey Thompson: "Too Much Horsepower is Almost Enough" Last edited by WARP TEN; 11-21-2017 at 01:31 PM. |
11-18-2017 | #9 | |
11-18-2017 | #10 |
Secondaries work great on my 90. Love the DR Jekyl Mr Hyde character of the car!
Sent from my SM-N920V using ZR-1 Net Registry mobile app
1990 Black/Black ZR-1 #1155 1993 White/Red coupe (Regrettably sold) |
