![]() ![]() Join Date: Mar 2008
For those of you that have replaced the thermostat on the LT5, how did you get the thermostat to stay in place while postioning the the housing back on? Thanks!
Roy L. Carman If I feel the need for speed, I just think about flying the B-777. ![]() 1989 Dk Blue Coupe lost in divorce 1991 Black Coupe SOLD 1992 Black ZR-1 #423 SOLD! 1993 Ruby Red 40th Anniversary ZR-1 #334 1995 Black ZR-1 taken by ex-wife 2002 Pewter Coupe no idea where it is 2003 50th Anniversary Corvette #No idea what number SOLD! ZR-1 Net Registry #516 Grand Sport Lifetime Member NCM Lifetime #1468 ZR-1 Net Registry Board Secretary |
![]() ![]() ![]() Join Date: May 2007
Same as cliff... it's also easier to attach the short hose to the top of the thermostat housing and the radiator before attempting reassembly.
Here are some other tricks. Note the arrow or notch in the replacement thermostat as that is the direction the thermostat needs to face towards the radiator. Also the backside of the housing bolts are threaded through so you can shoot some PB lube on the backside of the bolts before attempting to loosen the bolts as they are prone to snapping. GC
I used a little bit of super glue it worked great.
Sent from my XT1585 using ZR-1 Net Registry mobile app |
Thanks. The problem, that I am having, is the thermostat still popping out of position even though I used the putty knife. It leaked like a sieve. Tomorrow, I will use some permatex on it and see how that works. I did this long ago and did not have any problems.
Which bolt goes into the bracket - the short one or the long one?
Nevermind. I just answered my own question.
