Old 10-25-2017   #1
Leroy1
Default Vacuum Pump Installation
Gents,
Discovered the vacuum pump in Mary Jane's '91 is laying loose in the right front corner under the headlight. Appears that it should be mounted using a bolt at one end and a tab at the other, but cannot determine the location within the reach of the attached vacuum line and wiring.
Would appreciate any clues available as to how it mounts; a photo if possible. Cannot use my '91 as a go-by as its vacuum pump is long gone. The Helm Manual Electrical Section 8A-22-12 gives a vague written location, but does not provide a diagram. !#$%^
Regards,
S. Lee Sikes, '91 Dark Red / Saddle (pumpless)
Mary Jane Sikes, '91 Polo Green / Saddle (loose pump)
Leroy1 is offline   Reply With Quote
Old 10-27-2017   #2
Leroy1
Default Re: Vacuum Pump Installation
Problem solved.
Old 10-27-2017   #3
Glad you figured it out..
