Old 10-21-2017   #1
5ABI VT
Question Rear Main seal replacement questions. Pics !
Just pulled my cover off with the seal. Soon first look I thought somehow the seal was faulty but it was just dried sealant/gasket maker and it wiped clean. Thoughts ? N
Have a new main seal from Jerry about to go in.. any tips or suggestions on install and/or sealant or grease type to use on the seal ? Jerry reccomended grease and that was my first thought. Tia !
Wiped clean
Old 10-21-2017   #2
5ABI VT
Default Re: Rear Main seal replacement questions. Pics !
Ok so seems the outer of the seal to housing has rtv as well. Any tips or suggestions on getting it out ? Drilled a few screws through it and it won’t budge. Don’t want to nick the housing for obvious reasons.
Old 10-21-2017   #3
ssrszz4
Try putting small vise grips on rubber. Well holding them tap with block of wood.
ssrszz4 is offline   Reply With Quote
Old 10-22-2017   #4
5ABI VT
Managed to get it done .. thanks for the input. I was having a tough time given I didn’t want to take any chances nicking or bending the housing or scratching up the inner surface.
Now I’m just undecided as to what I should use for a lube on the seal part that contacts the crank. Any thoughts ? I have amsoil moly grease, online I see some recommending motor oil but I can’t be certain when I will finish, and marine grease etc.
Old 10-22-2017   #5
Jagdpanzer
Jagdpanzer's Avatar
Use a good molly gp grease
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 10-23-2017   #6
5ABI VT
Ill have to research what gp means Im not familiar with greases at all
I do have this stuff https://www.amsoil.com/shop/by-produ...grease-nlgi-2/
Sucks to be in canada. Beautiful day today spent driving around trying to find a pilot bearing puller and no luck. looks like ill have to order one and wait even longer
Old 10-23-2017   #7
Hog
GP=General Purpose
peace
Paul
