Old 10-13-2017   #1
Default Billy Boat or Borla?
If I can find access to a 4 post lift I'm going to put an exhaust on my car. Don't really want Corsa so I'm looking at options,i understand the drone issue has been fixed with the BB and Borla.
Old 10-13-2017   #2
onetinsoldier
Default Re: Billy Boat or Borla?
I have B&B in one car , its quality that's for sure ! And Borla in another !
onetinsoldier is offline   Reply With Quote
Old 10-13-2017   #3
Billy Mild
Borla is fine, i just hate how the tips look.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 10-13-2017   #4
secondchance
I ran Borla on my 1991 ZR-1 back in the early 90s. Back then Borla was the only aftermarket HP exhaust available for Zs.
My understanding is that Borla exhaust diameter pinches as it enters resonators.
Also, I recall seeing a post that solution to B&B resonating may have resulted in creating restriction to flow.
Another option is OBX. These look almost identical to Corsa. However, OBX uses more conventional sound reduction strategy - namely perforated pipe with fiberglass insulation ins the chamber. Resulting sound is more mellow but deeper growl at full throttle.
I have been running OBX since 2013 (I think...) and only complaint I have is the exhaust clamps supplied with the kit are junks. I installed my OBX using Torca clamps.
Old 10-13-2017   #5
Vette73
I'm running OBX as well...Really like the sound but it is does drone in 6th gear.....All though I'm not really in 6th that much...
And yes the fitment and the clamps suck....
I noticed that when I got my bill from my mechanic....
Sent from my LG-TP260 using ZR-1 Net Registry mobile app
Vette73 is offline   Reply With Quote
Old 10-13-2017   #6
secondchance
That's odd... I have no drone even in 6th. Are you running headers or factory exhaust manifolds?
Fitment issue? Is that what the mechanic told you? It was no better nor worse compared to Corsa.
Old 10-13-2017   #7
Vette73
Obx headers....
Old 10-13-2017   #8
secondchance
Obx headers....
I have the same setup.
What rpm are you sensing the drone? Can you describe it? Are you running resonators?
Old 10-13-2017   #9
Drone will be different from person to person. Everyone’s ears work differently what might be drone to some will not be to others..
Old 10-14-2017   #10
Mr.Yuck
I've tried them all and I think Billy Boat is the exhaust system that our cars are meant to run.
Sent from my 2PS64 using ZR-1 Net Registry mobile app
Mr.Yuck is offline   Reply With Quote
