07-14-2017 | #1 |
Liners/Nikasil
I'm talking with a company about the possibility of replating pistons and liners. Their concern was keeping the liners round for honing. How were the liners originally held for honing? Would a fixture block with a light press fit, that simulated the fit in the block, be sufficient?
07-14-2017 | #2 |
Re: Liners/Nikasil
It depends on the device you would use to hold it while honing, i.e. 2 jaw vise or 3 jaw chuck. The 3 jaw being best but also the most complex. FOr either style, I would recommend soft jaws that have been bored to the same I.d. as the upper ( largest) diameter of the cylinder sleeve.
For a 2-jaw fixture, the jaws could be cut from a single block of aluminum, say 10"x10"x2", then cut in half. Leave them "floating" to align with the sleeve. For a 3-jaw chuck, make a set of blank soft jaws that will bolt to the chuck. Then chuck up a slug at the rear of the chuck jaws & bore the 3 mounted soft jaws to the correct dia. It's not going to take much clamping force to hold the sleeve for honing and no more than necessary should be used. The sleeves are a "slip-fit" into the block, not even a light "tap-fit". So it's not necessary to clamp the sleeve tightly to simulate installed conditions. The real force on the sleeve comes axially from the clamp force applied when the cylinder heads are installed. Consequently, the sleeves would need to be installed and a torque-plate used to duplicate the installed conditions, then honed. It's going to require a diamond hone to cut nikasil.
07-14-2017 | #3 | |
Re: Liners/Nikasil
07-26-2017 | #4 |
Re: Liners/Nikasil
I'd stick em the block and use the torque plate to hone them
anyone need some stock liners to experiment with?
