Old 06-17-2017   #1
Jim Stanley
Default Vacuum Pump
With the key in the On position the vacuum pump keeps running. Occasionally it stops for a second and then keeps running. Is it supposed to stop? Does this mean I have a leak?
Thanks,
Jim Stanley is offline   Reply With Quote
Old 06-17-2017   #2
secondchance
Default Re: Vacuum Pump
Thanks,
Yes. You have a leak within secondary vacuum system most likely under the plenum.
Old 06-17-2017   #3
Jim Stanley
Thanks for confirming. Can't wait http://zr1.net/forum/images/smilies/icon_neutral.gif
Old 06-17-2017   #4
G8nightman
G8nightman's Avatar
Make sure you don't burn out the pump I would disconnect it till you fix the leak. I seen people asking as much as 400 for the pump
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 06-17-2017   #5
$400? Wow. I gave mine away after pulling the secondary SOB's; never looked back!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 06-17-2017   #6
S.hafsmo
S.hafsmo's Avatar
You should first try to disconnect the line going to the plenum from the pump, and hold your thumb over the pump side hose. Then you'll know if the pump/hose is good. Then you could try to disconnect the vac hose from the driver side of the plenum and plug the hose with your thumb. If the pump then stops, it's the check valve.
Sent from my SM-N910F using ZR-1 Net Registry mobile app
- '90 ZR-1
S.hafsmo is offline   Reply With Quote
Old 06-17-2017   #7
Young1
Young1's Avatar
I had to replace a vacuum solenoid valve under the plenum. There is s thread for it. Original is discontinued But DELCO sell one one you just change the bracket. Just go bit by bit systematically.
Steve Young
Second Owner
SOLD
SOLD
Old 06-17-2017   #8
PhillipsLT5
PhillipsLT5's Avatar
I gave mine away also, at least it was to a friend
Old 06-18-2017   #9
The pump can be found new shipped to your door for less than $130,same pump used in a KODIAC KICK,direct bolt on for 91-95,plug is different for 1990. Anybody know the part number for the new solenoid valve?
Old 06-19-2017   #10
Check with Jerry Downey @ Jerry's Gaskets.com
90 #1202
Sans secondaries
