05-17-2017 | #1 |
Itty Bitty Bulb needed
Where do I get the little bitty light bulb that illuminates the electric window switches? It removes from the body of the switch with a tiny screwdriver. It is a yellowish orange color. Burnt out. I am type A and enjoy victory over the small things too.
05-17-2017 | #2 |
Re: Itty Bitty Bulb needed
If possible see if there is still a legible part number on the bulb. Then check the parts stores, etc. I have never seen any listed for that application.
05-17-2017 | #3 |
My parts book says 10148011:
http://www.ebay.com/itm/NOS-OEM-GM-L...VXq42x&vxp=mtr
Roger 1990 ZR-1 #2699 Black on Black 15,000 miles Full-time secondaries, 4.10 gears, C-beam plates, ported top end |
05-18-2017 | #4 |
Thanks so much. Part number is accurate for complete switch assembly. The itty bitty bulb is not a separate part number. Maybe I can find one at Carlisle. A 1,600 mile road trip for a $1.60 part makes sense to me![emoji41]
05-21-2017 | #5 |
$25 for a bulb,why do people keep doing business with that hack.
05-21-2017 | #6 | |
This is the bulb only! OP - I've never attempted to match the bulb/socket and I've only ever seen it referenced to a Stanley # If you've the bulb/socket removed presently I'd try to compare dimensions to a T3, T4. Dimensions are in the link. http://www.autolumination.com/74.htm Easier to read dimensions https://www.ebay.com/p/?iid=382069402972&&&chn=ps Many years ago I did several switch back-lighting projects for other than Corvette projects that used some Pontiac/Olds/Buick lighting. I believe I actually sourced most of the project using MOPAR. This is from a later C4 FSM - Bulb charts are in the 8B & 8C sections of the FSM. The Stanley reference information is there also. Switch lighting.jpg Last edited by WVZR-1; 05-21-2017 at 09:43 AM. |
05-21-2017 | #7 |
Now we are on to something with the auto illumination link. I will continue with updates. I will get some extras to share!
05-21-2017 | #8 |
It's a Sylvania Size 74. I have replaced them many times before. However just reading the thread above it appears WV has you in the right direction. GC
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 05-21-2017 at 06:51 PM. |
05-21-2017 | #9 |
05-21-2017 | #10 |
Gentlemen 74 is not the bulb. Open the link of BlackZR1. The black and orange is the bulb. But 10148011 is the part number for the door switch assembly that contains the bulb. GM does not have a part number for the bulb itself. WVZR1 is on track with the T3 or T5. Anyone have a source?
