Old 05-12-2017   #1
Fully Vetted
Fully Vetted's Avatar
Default Can't find new tires in my size??
I'm running 18" Shelby's with 335/30's and 275/40's. Suddenly, I cannot find a manufacturer in those sizes. Michelin no longer makes a tire that wide. I ordered a set of Pirelli's and took them up to discount tire and they won't even mount them because the load index for the front on this car has to be a 98 and these are a 95. Finding a 275/35/18 with a load index of 98 or higher isn't an issue. But finding one that also makes a 335/30 is impossible. What are you guys that have 18's running for tires?
I guess I could just take the tires and wheels up and if they ask tell them it's a custom rod or something. I just hate to lie about what it's going on. Bad carma...
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 05-12-2017   #2
BigJohn
BigJohn's Avatar
Default Re: Can't find new tires in my size??
Have your tires mounted on your rims take them home and put them on your car.
Old 05-12-2017   #3
Just how bad do you want those tires mounted?
Old 05-12-2017   #4
Jagdpanzer
Jagdpanzer's Avatar
Main reason why I went with 19" rears when ordering new wheels a while back.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-12-2017   #5
JimZRyd
JimZRyd's Avatar
Dang David. Sorry to hear about your troubles. Like it was mentioned above, that's why I went with 19's. I also had the tires mounted on the rims, and then took them home for me to put on the car. Good luck in your quest!
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 05-12-2017   #6
ssrszz4
I would not worry about the load rating if it's that close. The tires on my truck are rated only to 99 mph but on the dyno my top speed was 155.
ssrszz4 is offline   Reply With Quote
