Anybody got a tip on removing tensioner while in the car? Its a b*tch to get to. Removed airhorn for better access, plus gap between it and compressor did not alllow for belt removal. I have a chirping sound that follows engine speed. I undid the belt today and got no noise running the motor but no accessory drives.
Is it necessary to remove the evap canister and coolant crossover in order to get a grip on undoing bolt? I get a "click click" from tensioner as I spin it w my finger altho it spins smoothly. But I can hear the bearing. All other accessories make no noise. Very slight wobble in alternator pulley. Belt had a small chunk of one of the ribs missing. |
![]() Join Date: Jul 2015
You're most of the way there, air horn off and a ratcheting box wrench (low profile is key here).
Space is at a high premium in the front of the LT5... Sent from my iPhone using ZR-1 Net Registry
1991 ZR-1 #1438 Black/Black & Red |
#3 | |
I'm a fan of the pipe extension breaker conversion
![]() I will say that in putting it back on you should be able to tighten it enough with the wrench, but not so much as to need anything crazy to get it back off in the future. Sent from my iPhone using ZR-1 Net Registry
#5 | |
![]() Join Date: Nov 2007
FWIW, if you can't find the stock ZR-1 tensioner pulley, I am using one for an LT1 motor: it's flat, i.e, sans the ridges on the sides of the pulley.
At the time, I bought it over the counter from a local Chevy dealer. |
My understanding Paul is that u can use a LT1 pulley to rebuild the LT5 pulley.
#8 | |
Sent you a picture: Using a ratchet, box-end wrench, it is possible to access the 18mm bolt on the tensioner, WITHOUT moving/removing the A/C evap., nor is un-hooking one end of the coolant cross-over pipe necessary. Furthermore, removing the air-horn is optional, and if you can avoid removing it, so much the better. Oh, it is tight; the front of an LT5. But, you should be able to do the tensioner w/o drastic measures (e.g., a pipe on the box-end wrench?) Cheers! |
#9 |
![]() Join Date: Dec 2003
#10 | |
This Belt Tensioner Pulley will fit the ZR-1 (LT5) as well as a standard C4 with L98 engine. Ebay Billet Aluminum Belt Tensioner Pulley ![]() Rather than a pipe on combination open end......just use another Combination wrench box end on the Open End......... ![]() To get the 1/2 inch socket into the 1/2 inch square receiver of the Tensioner (for release of the serpentine belt), just lift the Tensioner a bit with broom handle and insert socket.....then compress Tensioner. Like Paul suggests....no need to remove ANYTHING to remove the Tensioner. Use a bit of Blue Loctite on Tensioner Bolt when installing and tighten just enough..... ![]() ![]() I actually remove the Alternator Pulley when installing new belt as I have a "special Tool" to remove that alternator nut in a few seconds. Then I place the alternator pulley in the tensioner belt and install the pulley on the alternator.....DONE DEAL. ![]() ![]() Oh.....by the way.....I invented a New Way to install the Serpentine Belt......Remove the Alternator Pulley (takes 1 minute) and position NEW Alternator Pulley inside Serpentine Belt and lift up the Alternator Pulley and Serpentine Belt with Belt Tensioner compressed (Keep Serpentine Belt aligned with Belt Tensioner Pulley). Now just slip the Alternator Pulley onto the shaft (very easy to do and plenty of play) and tighten up the 15/16 inch Alternator Pulley Nut. All Aluminum Alternator Pulley
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-20-2017 at 04:06 AM. |
