04-12-2017 | #1 |
Injector Duty Cycle > 100%?
Did some data logging over the weekend with TunerProRT and Jeff's adx.
When I floor it and rpms go over 4,000 rpm, Injector BPW values run around 21ms. When I calculate injector duty cycle with rpm above 5750 and 21ms BPW I get values above 100%. What am I doing wrong? I am using this formula: Injector BPW (ms)/(1000*60*2/RPM)*100 which gives me similar values (>100%) as the calculators I find on the web. Maybe BPW is not the same as PW? I attached my log file if someone has a few minutes to explain what is going on. Car is all stock, newer injectors of unknown spec. Using Marc's AYBKG5 chip with full-time secondaries. Thanks, Roger
Roger 1990 ZR-1 #2699 Black on Black 15,000 miles Full-time secondaries, 4.10 gears, C-beam plates, ported top end |
