Old 03-11-2017   #1
garyhugo
garyhugo's Avatar
Default Oil Pressure
Over the last couple years and 6000 miles or so my oil pressure gauge has more and more often began to bounce.I'd say 10 psi or so when driving. It will do it under throttle or coasting.It does it half the time anymore.I've changed the oil pressure sensor and it still does it.Is this a sign of catastrophic failure just around the corner? The engine has 172000 but not particularly hard miles.
Gary
90-1572
garyhugo is offline   Reply With Quote
Old 03-12-2017   #2
Default Re: Oil Pressure
You sure you changed the correct sensor? Could also be in the Cluster Oil Pressure Electronics. What is your oil pressure cold and hot at idle?
I doubt that a bouncing oil pressure has much to do with the Oil Pump or Oil Filter Adapter. I would say that be indicative of electronics associated with Oil Pressure Sensing.
Just curious.....what has been done to the engine? Have you ever installed new Timing Chain Guides?
What engine oil you using and how often you change oil? (just asking having not much to do with your question)
I may have some more questions as 172,000 miles is an interesting milestone regarding the LT5.......... proving longevity.
I recall only 3 others have over 150,000 miles and a couple over 200,000 miles.
Old 03-12-2017   #3
efnfast
Cliff, dude, you got the best stuff (those pictures).
Old 03-12-2017   #4
garyhugo
garyhugo's Avatar
Cliff, that's reassuring to hear it's not the oil pump getting ready to quit.Yes I replaced the oil pressure sensor for gauge.The old one pegged high when cold and dropped down to around half when hot. The new one shows 3/4 when cold and 1/4 when hot.Haibeck did top end porting and under plenum service around 130000 or so.I run mobil 1 gold cap 10W30 and change it and filter when service light comes on usually about 3300 miles.
Gary
90-1572
Old 03-12-2017   #5
garyhugo
garyhugo's Avatar
Never installed timing chain guides.
Gary
90-1572
Old 03-12-2017   #6
I guess I would remove oil pressure sensor and check oil pressure with a mechanical gauge to make sure ......then if OK must be in Cluster oil pressure readout.
Old 03-12-2017   #7
Hib Halverson
When you say "service light comes on" do you mean the "change oil" light?
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 03-12-2017   #8
garyhugo
garyhugo's Avatar
Yes Hib.
Gary
90-1572
Old 03-12-2017   #9
garyhugo
garyhugo's Avatar
I'm going to go to Auto Zone and get the Pro Form oil pressure tester.Then I'll know for sure wheather the oil pressure is steady or bouncing. I do have a question though, would you use teflon tape on the threads when changing back and forth from sensor and tester?
Gary
90-1572
