Old 03-09-2017   #1
msorenso
msorenso's Avatar
Default Sway Bar Selection & Size
Does anyone know the size of the front and rear sway bar on a 91 ZR1?
Also has anyone changed out and to what brand and size with what results? Thank you
msorenso is offline   Reply With Quote
Old 03-10-2017   #2
RussMcB
Default Re: Sway Bar Selection & Size
This will get you started. It lists the sizes that came on C4 Corvettes.
http://www.netmotive.net/articles/hib/c4/sustunch.pdf
Old 03-13-2017   #3
msorenso
msorenso's Avatar
Thank you for the response.. Please if anyone has used aftermarket swat bar please fill me in
Old 03-14-2017   #4
5ABI VT
I searched and found a solid 32mm bar that was gm and used it. I think it was from this forum but late c4s I believe are interchangeable. Noticeable difference for me. Always on my first mods-list. makes the front end much flatter and sharper feeling.
Old 03-14-2017   #5
G8nightman
G8nightman's Avatar
You left the stock bar in the rear?
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 03-14-2017   #6
RussMcB
When I bought my Z I assumed I'd want to stiffen the ARB's and maybe springs, but after 2 years and 5-6 track days, I'm very happy with how it handles. It's neutral and predictable at the limit. The sway isn't noticeable enough to hurt the performance (on my scale). A blast!
The only updates/maintenance I did was new shocks, lowering bolts in the rear, new tires and a very good alignment.
I'm sure it's different for others, a personal preference.
Old 03-14-2017   #7
5ABI VT
Yes if I remember right the z has the 26mm solid bar in the back because of the wider tires and wheels. On my lt1 car I put the 26mm because I run 11s but it seemed a little form and only helped slide the rear around so I figure 26mm is plenty for the z
Old 03-15-2017   #8
Hib Halverson
GM never made a 32-mm front bar for a C4.
Even if it did make a 32, just bolting that one with no other changes, might make the front end..."much flatter and sharper feeling," but the overall effect on handing at the limit would be decidely negative because, going up 2-mm in the front, would increase, not decrease, understeer so you'd go into turns with the front end leaning less but also the car would be going slower.
My guess is your "32-mm front bar", if it's from GM is really just a stock 30-mm bar.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 03-15-2017   #9
5ABI VT
I thought I recalled the biggest gm bar being 32 but looks like 30 is the one. hmm.. I cant even remember what size mine is. Theres a lot of variables that come into play to determine wether or not a car would be slower or faster including driver preference. Much flatter and sharper is worth it for me. If I cared about actual numbers than I would be in a c5z or a different car.
