Old 02-20-2017   #1
secondchance
Default Steering rack install
About a year and a half ago started to notice a bit of dead spot going straight. Also started to notice a sensation of front tires skipping under heavy acceleration. These symptoms were followed by outer edges of front tires wearing rapidly. Last summer I had my car on Rich's lift. With front end raised, moving the front tire/wheel left and right, I could hear light clanking noise coming from tie or dinner ends. I could just replace the tie rods but since I have racked up 158,000 miles, figured might as well replace the entire rack.
Of course, there are no NOS steering rack available. All major Corvette parts stores, Mid America, Corvette Central, Zip, Ecklers, and a few vendors on Ebay carry rebuilt units. Typical price ranged from $219 to around $400.
My preference would have been to have mine rebuilt by reputable rebuilder such as Turn One, but not an option since I didn't want to tie up Rich's lift for weeks.
For what it's worth, figured reputable Corvette Vendor (as opposed to unknown Ebay vendor) may have better quality control - I hope!
Luck would have it, Ecklers's had $50 off sale which reduced the price to $169 (or so) plus shipping (I think $49) and $300 core charge. Also, picked up some GM power steering fluid.
Old rack and new. New rack with tie rods eyeballed to the same length left and right with shaft connection clocked the same.
Rack ready for removal with roll bar and power steering cooler unbolted and out of way.
New rack in place and cooler re-mounted.
Phil, Jim, Gibby and Al joined me and Rich and pitched in to help. Phil's "gentle" persuasion was necessary to remove the old unit.
After 8 hours of frustration, a lot of help from Rich and a pair of very greasy hands, no more sloppy ride and crystal clear power steering fluid!
Old 02-20-2017   #2
Roadster
Roadster's Avatar
Default Re: Steering rack install
Sounds and looks like a very successful day....great pics....
Is that your build date in pic #3 which looks like 3 21 94? Or do those numbers have a different meaning???
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-21-2017   #3
secondchance
Great eyes! I guess so...
Old 02-21-2017   #4
Scrrem
Scrrem's Avatar
Yeah Yun, it was a bit of a scary job but as unusual, WAZOO prevailed. I got really concerned when backing that rack bolt out and it butted itself against the front cover of the motor. You and the pry bar became good friends...LOL! We can tackle those lower ball joints another day.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 02-21-2017   #5
WVZR-1
That looks to be cross-member part# 10205043 and build information for that component. It might be interesting to compare the 3/24 date to the Certification Label mo/year info OR if Yun actually has the build sheet then compare the two dates.
Old 02-21-2017   #6
secondchance
Unfortunately, my build sheet is still glued to the gas tank. I saw it when the rear bumper was removed for painting but left it alone.
Old 02-21-2017   #7
secondchance
Rich
I think my lower ball joints are still good. I never slacked when it came to greasing them. More importantly, never got so greedy to pop the boot with excessive grease.
Old 02-21-2017   #8
secondchance
WVZR-1,
Hope all is well.
Are you able to check if power steering cooler is ZR-1 specific or the same unit used for LT1/LT4 cars?
Mine looked a bit banged up. If it's the same with LT1 cars, I can pick up a good used one, clean it and replace.
Old 02-21-2017   #9
WVZR-1
WVZR-1,
Hope all is well.
All seems well! Thanks for asking!
By application it's '92 - '95 LT5 cars only!
Old 02-21-2017   #10
secondchance
Happen to have GM part number by any chance?
