Old 02-13-2017   #1
Default LT5 Idle w Pete's cams
Playing in the garage since temps are near 40 (Awesome weather for ORD)
Had motor idling just to warm things up and test new alternator so I thought I'd document this. Motor running well.
BTW, both Intake and Exhaust.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-13-2017   #2
Roadster
Roadster's Avatar
Default Re: LT5 Idle w Pete's cams
Your engine sounds real good, very smooth.....
btw, is that a crack in your gauge cover?
Scratch.
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-13-2017   #3
efnfast
Boy, I hope my car idles that nice. Altough, I do like that cam lope.
Old 02-13-2017   #4
This is in Closed Loop.
Old 02-13-2017   #5
efnfast
How does that change things Dom?
Old 02-13-2017   #6
Most tuners, of the ones I know of, tune "cams" in Open Loop. Closed Loop allows modification of fueling based on O2 input and allow me to manipulate
parameters that are not enabled in Open Loop. In my experince, tuning in Closed Loop gives me more control over how engine will operate in a variety of situations resulting in more consistent operation.
It takes more time but it works for me.
Old 02-13-2017   #7
jss06c6
Very nice Dominic! Is that where you are going to mount the wideband display. Love the digital and the exhaust temp!
Steve
Old 02-13-2017   #8
Steve
Steve,
I have the console apart for installation of an appRadio4. The display comes w the Zeitronix ZT-2 WB that I have used for about 10years. The display has
AFR, MAP v, and Lambda. The EGT isn't working although it can be plumbed into the WB datastream. I use a 14.3 AFR for stoich since we have 10% Ethanol here in the Midwest, so I really look at Lambda for tuning purposes.
Old 02-13-2017   #9
jss06c6
Steve,
Nice! Need to chat about 10% ethanol Stoich and tuning impact.. I calculated 14.11 here in Houston. Topic for another time.. I'll drop you a note regarding my WOT runs yesterday...
Steve
