01-14-2017 | #1 |
fuel flowing from air intake
1990 ZR1: Started engine but after about 2 minutes it stalled. Tried to restart but no luck. Smelled gas and found large puddle at front of car. Removed air filter and found large amount of fuel coming out of the plenum. Any suggestions? Please?
1990 #1507 Black/Grey/flowmaster-DRM chip |
01-14-2017 | #2 |
Re: fuel flowing from air intake
Fuel pressure regulator might be bad or stuck injector pull the spark plugs out to purge out the raw gas so you dont bend a valve
01-17-2017 | #3 |
When that happened to my car it was the fuel pressure regulator, leaking.
01-18-2017 | #4 |
Thanks for the info. I'll try the pressure regulator first. Anybody else seen this happen?
01-18-2017 | #5 |
I had a similar issue. Turned out to be the fuel pressure regulator also.
01-18-2017 | #6 | |
Jerry's Fuel Pressure Regulator Rock Auto Fuel Pressure Regulator
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-19-2017 at 11:26 AM. |
01-19-2017 | #7 |
Hi,
I see two part numbers: 1990 to 1992 is 17112220 1993 to 1995 is 17069632 Are they interchangeable? Thanks, Bill
LT5 Red/Red |
01-19-2017 | #8 |
Is there any way to replace the diaphragm in the regulator?
That's pretty much the only part in them that could go bad... |
01-19-2017 | #9 |
No its unserviceable
01-19-2017 | #10 |
