Old 12-15-2016   #1
S.hafsmo
S.hafsmo's Avatar
Default WTB 90 ZR1 Exhaust w/Resonator #39399
Currently looking for the center part of the ZR1 exhaust.
Can't buy the whole thing, as it's just to massive to ship over seas.
The part I'm looking for is #39399 on this drawing.
The most important bit is the one between the two mounts on each side of the center resonator (incl. the mounts), and a few inches in front of the forward mounts.
My resonator has been replaced with this:
And I am not quite sure a Corsa would pass the inspection here in Norway.
S.hafsmo is offline   Reply With Quote
Old 12-15-2016   #2
Mr Blue
Default Re: WTB 90 ZR1 Exhaust w/Resonator #39399
Are you looking to maintain the stock 1990 exhaust system? If not the later 92-95 resonator offers better flow and more power. The internal pipe diameters are significantly larger.
Mr Blue is offline   Reply With Quote
Old 12-15-2016   #3
S.hafsmo
S.hafsmo's Avatar
I'll probably get the Corsa at some point, so flow is not really that important.
Is the rest of the post 92 exhaust the same? If I cut my exhaust before and after this "modification", would a similar piece from a later exhaust fit?
Sent from my SM-N910F using ZR-1 Net Registry mobile app
- '90 ZR-1
Old 12-16-2016   #4
Mr Blue
Yes, the late resonator will mate to the earlier pipes. It does not need to be a ZR-1 resonator, any 92-96 resonator will be lower restriction.
Old 12-16-2016   #5
S.hafsmo
S.hafsmo's Avatar
Interesting. Maybe I'll be able to acquire those parts on this side of the pond, if any post 92 stock exhaust resonator will do.
Old 12-16-2016   #6
If you can find one a factory LT4 resonator was considered to have the best flow however those can only be found on 1996 LT4 equipped C4s
Old 12-16-2016   #7
S.hafsmo
S.hafsmo's Avatar
Probably unlikely I'd find one. Lt1 resonator - maybe.
Old 01-09-2017   #8
billschroeder5842
billschroeder5842's Avatar
I have a 93 resonator in great condition that will weld on perfectly. From my research Chevrolet used the same resonator with the 2 5/8 inside diameter for all LT1, LT4, LT5 applications from 92-96. PM me if you are insterested. Thanks!
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
