Old 11-02-2016   #1
alexco
Default ZR1 quites running after short distance
Looking for some suggestions on my 1990 ZR! which I recently purchased. I bought the car knowing this problem exited. After driving the car 1/4 mile to a mile, the car just stops. Appears to be out of fuel. The previous owner put in a complete new fuel pump assembly to no avail. One thing he did have done was have someone put in a new ignition switch about the same time as the problem started. How and what would the ignition switch do to cause this problem. The switch is inexpensive but would like to understand why this would occur. What other potential areas would cause the same problem. Thanks for any help.
Alexco
alexco is offline   Reply With Quote
Old 11-02-2016   #2
Default Re: ZR1 quites running after short distance
Alexco
How/when do you get it started again?
Old 11-02-2016   #3
alexco
It usually has to sit for sometime, but there is occasions after about 5 mins it will start up.
Old 11-03-2016   #4
2ljd
Fuel filter?
2ljd is offline   Reply With Quote
Old 11-03-2016   #5
Although you state the fuel pumps were replaced it certainly seems like that is still the problem. Does the car just die? Are the electronics still working it just quits running. Is a security light flashing ?
Old 11-03-2016   #6
And after it starts up, does it stay running or quit again?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 11-03-2016   #7
dredgeguy
dredgeguy's Avatar
Did you replace both fuel pumps, primary and secondary?
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 11-03-2016   #8
Fully Vetted
Fully Vetted's Avatar
I'd start with testing the pumps (follow the procedures in Solutions. Takes 10 mins) or hooking up a fuel pressure gauge. My guess...filter.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 11-04-2016   #9
alexco
Yes, both pumps, the entire assembly. I just purchased a filter and will replace it today. I have been chasing it as an electrical issue, but I think you guys might be right with the filter. I will find out this weekend. If there was an electrical issue, where would you look? I appreciate everyone's help.
thanks
Old 11-04-2016   #10
alexco
Once it starts in the garage it will run for a long time, not stopping. Which again could point to the filter, at idle, low fuel flow, driving, higher RPM;s, more fuel. As I said earlier I will know this weekend.
Thanks again.
