Old 10-28-2016   #1
gen2rt
Default Failed emissions
94 zr1 with haibeck top end work. Headers, no cats.
Passed everything except the hc at idle. Allowable limit is 220. Tested 3 times, read 561, 260, and 461.
Car sat for two years, I think I've run most of the bad gas through it, currently on second tank of fresh gas, added fuel system cleaner to both fill ups. Only issue with the way it runs is an off-idle stumble.
Ideas?
Thanks,
Jack
gen2rt is offline   Reply With Quote
Old 10-28-2016   #2
Default Re: Failed emissions
move to another state
Old 10-28-2016   #3
probably a tune someone could do for the test
Old 10-28-2016   #4
Kevin
Kevin's Avatar
Injectors going bad?
Old 10-28-2016   #5
gbrtng
gbrtng's Avatar
put cats on it
Old 10-28-2016   #6
gen2rt
Well, yeah, putting the cats back on is the obvious solution, but I've seen posts where they've passed without them. And it's fine at higher rpms. I'm thinking its related to letting the car sit. The way it acts from zero throttle to a little bit open, if it was carburator, I'd look at the accelerator pump. I don't know what the equivalent to that is with fuel injection. Was hoping to hear from someone very familiar with the fueling systems and what might be causing it to run rich just at idle. The car has only 19,000 miles, new plugs were put in about 2,000 miles ago. I hate to go the effort and expense replacing the injectors and then discover it doesn't run any differently. The secondaries are wired open, if that makes any difference.
Old 10-28-2016   #7
mike100
The tune is adding fuel and timing which will raise emissions, but you could still pass if you had the oem cats. Not having cats with a chip...you don't have a prayer. At least put a stock chip in it.
Old 10-29-2016   #8
mike100
I'm expecting my registration renewal in the mailbox any week now. My car passes normally, but I'm curious to see if I cheat like VW to lower the NOx, how much it will help.
Old 10-29-2016   #9
BigJohn
BigJohn's Avatar
Replace cats
Old 10-29-2016   #10
Ideas?
Thanks,
Jack
No CATS = no PASS
