10-07-2016 | #1 |
Sticking Brakes
Not sure which one or how, but after a while driving around I will notice my brake pedal become rock hard up high and that my car won't roll back if stopped on a hill. I can drive and if it cools down it goes back to normal. I was thinking about taking it up to brake check, but figured I'd see what y'all think first.
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI. |
10-07-2016 | #2 | |
Re: Sticking Brakes
10-13-2016 | #3 |
Re: Sticking Brakes
An infrared pyrometer or even a careful wave of the hand near each wheel might narrow your search 75%.
I agree about the booster comments but that doesn't cover the "won't roll back until cooled" part of the concern. I'd suspect a sticky rear caliper for that part of the problem. Luck, - Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] |
12-14-2016 | #4 |
Re: Sticking Brakes
took the car out this morning to see whats what, under very hard braking I can activate the ABS light and it feels like it cycles once, then the car will slide into a cloud of smoke. I end up with both front tires in skid, based on the width of the tire marks and my 335's on the rear I can deduce the rear brakes are not locking up, just the fronts. Correct me if I'm wrong, but my car should not skid correct? What can lead to this condition?
12-14-2016 | #5 |
Re: Sticking Brakes
Happy to look at it with you.. I'm in Magnolia. Let me know how your schedule sets up tomorrow.. I'll PM you my cell number..
12-14-2016 | #6 |
Re: Sticking Brakes
I dropped it off at a local shop, hope they can get it right.
12-14-2016 | #7 |
Re: Sticking Brakes
12-14-2016 | #8 |
Re: Sticking Brakes
i can only handle so much frustration, gonna let the pros do a few things- brakes, suspension bushings, and an alternator.
12-14-2016 | #9 |
Re: Sticking Brakes
Might be your brake master cylinder how often do you change your brake fluid? Does the car pull when you brake? My friends 95 Z would not roll when brakes would heat up we replaced MC all good.
90 Chevy ZR1 LPE #2315 'SOLD' 90 Chevy ZR1 LPE #2774 'SOLD' 91 Chevy ZR1 Callaway aerobody 91 Chevy ZR1 #1512 91 Chevy ZR1 #951 95 Chevy ZR1 #338 'SOLD' 91 BMW 850i 94 BMW 850csi 95 BMW 850csi 94 Lotus Esprit S4 07 Benz CLS550 06 BMW M5 "SOLD" |
12-15-2016 | #10 |
Re: Sticking Brakes
Have you ever changed your front brake lines? I had an issue the same as you it was the inside of the front lines had gotten soft and were collapsing not letting the fluid go back to the master cylinder. As soon as I released the pressure by opening the bleeder on the caliper it released.
