Old 10-02-2016   #1
onetinsoldier
Default Fouled plugs ?
Ok I have #4 and #8 fouling repeatedly . I had the cat come apart on that side and cleaned it out , and I havent replaced the O2 sensor yet , any suggestions ? And its setting a code 64 ,lean exhaust . Thanks !
onetinsoldier is offline   Reply With Quote
Old 10-02-2016   #2
Default Re: Fouled plugs ?
Are the fouled plugs "oily" or "dry-soot"?
Old 10-02-2016   #3
onetinsoldier
looks like dry soot !
Old 10-04-2016   #4
onetinsoldier
Default What causes sooty plugs ?
I'm looking for an answer to a repeated problem , only 2 out of 8 plugs are sooty . Is it injector issues , plug wires , coils , plug gap ? Can backfiring be an issue ? All of the above ?
Old 10-04-2016   #5
32valvesftw
Default Re: What causes sooty plugs ?
Probably best to move this to the technical section to get more answers. In any case. There are many potential causes, if its only two plugs try moving things around, like move a spark plug and the wire from a known good cylinder to your suspect one. If the problem follows the plug and wire, theres your problem. You can do the same for the injectors but it takes a bit more work.
If your car is a 90, it may be leaking valve guides.
Has there been an increase in oil consumption? Any misses. Any recent Mods?
Plug chart below for your reference
https://www.google.com/url?sa=i&rct=...75710071916249
Old 10-04-2016   #6
Moved ! GC
Old 10-04-2016   #7
onetinsoldier
Its a 91 ,no new mods ,actually I think its stock , new ecm though . I replaced the plugs , same thing , i used a spark detector on every plug , no issue , now i did gap the plugs at 35 , maybe go to 50 ? I did a fuel leak down test for about an hour , no drop in fuel pressure.
Old 10-04-2016   #8
secondchance
How many miles? Do you know whether you have original injectors or they had been replaced? If replaced, which brand?
Old 10-04-2016   #9
32valvesftw
Coils on 4 and 8 weak?
Old 10-05-2016   #10
onetinsoldier
I have no idea what was done to the car , I am the third owner for 0016 . I would like to find the first owner and ask ! There is a sticker on the rear glass for ZR1 registry , so maybe they still visit the site !
