Old 01-16-2007   #1
ZR1FUN
Default Garman C330 GPs
I am looking at buying this for a cross country trip. I dawned on me that the ZR1 special windshield may interfer with it's operation. Does anybody have any experience with this?
Doug
ZR1FUN is offline   Reply With Quote
Old 01-16-2007   #2
Default Re: Garman C330 GPs
I have no direct knowledge but my EZPass would not work consistantly so I had to get the one mounted on the license plate. Also, my apt complex got a new Transmitter/reciever system for the garage doors and the remote works thru any part of the windshield....go figure?
Maybe a stick on antenna for the hatch glass & run the wire over the weather strip, it seems to be soft enough not to have a problem??
Good luck on the trip & have fun!
Old 01-16-2007   #3
Hammer
Hammer's Avatar
Doug
I have a Garmin Quest mounted high in the windshield and it doesn't seem to present any problems.
Old 01-16-2007   #4
GrayZ
Cool Re: Garman C330 GPs
my solo s2 works perfect...and i've stuck it all over the place
GrayZ is offline   Reply With Quote
Old 01-16-2007   #5
4DSZR1
4DSZR1's Avatar
I drove last October from Seattle to Las Vegas and back while using a Garmin Palm Pilot. Worked fine the entire trip. I had the clear roof installed at the time, so that may have helped getting a signal inside the car. There were a few times that the signal strength dropped down, but never really affected the performance.
You can see in the picture where my "co-pilot" had it mounted.
4DSZR1 is offline   Reply With Quote
Old 01-16-2007   #6
ZR1FUN
4DRSZR1 Do you still have the original windsheild in your ZR1?
Old 01-17-2007   #7
4DSZR1
4DSZR1's Avatar
Yes.
Old 01-18-2007   #8
ZR1FUN
Smile Re: Garman C330 GPs
Thanks guys! I got it. It should get here next week. Now I have to come up with a way to keep everything hooked up to power. Phone, detector and GPS. Oh the fun we have.
Old 02-05-2007   #9
spl642
I have a Garmin GPSMAP 496 and it didn't recieve a quality signal until i place a remote antena in the clear opening at the front of the dash. But my GPS does not stick to the window like some of the ones already talked about
spl642 is offline   Reply With Quote
